Getting positive voltage at the output grid - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 29th January 2017, 01:56 PM   #1
moggi1964's Avatar
Default Getting positive voltage at the output grid
The TSE was working (breadboard) when I packed it up and brought it to the UK with me. Swapped in the 240V version Edcor XPWR131 and wired the umbilical.
At checkout with rectifier in I get
B+ 414V
B- -216V
Filament 4.96V on each
When I try to get a reading on grid (clipping to pin 3 on the socket) to ground I get no reading on one and a positive mV reading on the other. I turned the pots at R12 and 23 but they didn't have an effect.
I have checked continuity across ground (to make sure the board is properly grounded as I know someone had a similar problem before and got positive readings) and continuity between the grids and the outputs at T3-2 and T2-2.
Any suggestions on what to check next please? Where could I measure to check continuity into the grid?
As those who know me will remember, I need as much non-technical direction as possible. I'm still learning which is why it's taking me so long, I'm trying not to make any dangerous mistakes.
Thanks.
TEAC RH 500 Amplifier Vista Phono1+ w/ TEAC TN-400. Loth-X Ion 1 BS & Emotiva XDA2. WIP: Tubelab SE 300b
Old 29th January 2017, 03:03 PM   #2
JonSnell Electronic's Avatar
Make, model schematic?
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 29th January 2017, 03:15 PM   #3
Always Learning
Make sure mm dial is in the right position.
Old 29th January 2017, 03:20 PM   #4
moggi1964's Avatar
Tubelab SE John
Old 29th January 2017, 03:33 PM   #5
moggi1964's Avatar
I'm glad you started with the obvious mkane as these are the kind of mistakes I make. Had one set for auto VDC and one set for 200VDC and then 20 VDC then 2VDC.
Is that correct?
Old 29th January 2017, 04:50 PM   #6
w5jag is offline w5jag  United States
Where did you measure the -216 vdc?
Since the fault looks to be common to both channels, I'd start by taking a look at R5 and R6 in the bias supply, to see if one or both has gone open.
Win W5JAG
Old 29th January 2017, 05:56 PM   #7
Got it.
There should be a negative voltage, with respect to ground on the grids of the output valves.
I am a bit new to types of amplifier models as I have only been designing and repairing valve amps since 1967.
I suspect a bias issue somewhere as w5jag writes.
Old 29th January 2017, 06:10 PM   #8
moggi1964's Avatar
W5JAG,B- measured at R7.
I'll check the resistors you suggest and get back.
Thank you both.
Old 29th January 2017, 07:26 PM   #9
Always Learning
Is that correct?
Rookie here also and seemingly it's the simple things I miss.
Old 30th January 2017, 08:15 PM   #10
moggi1964's Avatar
Rookie error.
Choose the wrong pin to measure from so was measuring from pin 2 instead of pin 3.
Readings now after adjustment with the pots showing -129v on both.
5842's going in next. I'll report back when that has happened, might be tomorrow or Weds.
Thanks everyone.
12AX7 Class 2 (Positive Grid Voltage) Operation Sch3mat1c Tubes / Valves 3 3rd September 2016 11:08 PM
Simple driver for positive grid tubes jps1964 Tubes / Valves 12 19th September 2015 07:48 AM
TSE checkout help positive grid voltage pbkrag Tubelab 1 21st December 2013 09:12 PM
805 Positive or Negative Grid FullRangeMan Tubes / Valves 10 31st October 2013 01:59 PM
Are Positive Grid Voltage Traces Necessary? crj11 Tubes / Valves 16 1st March 2010 02:28 PM
Copyright ©1999-2017 diyAudio
