Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 19th February 2017, 08:10 AM   #11
moggi1964 is offline moggi1964  England
moggi1964's Avatar
colnago, I too had measured before I installed them but also before I added a different value C5 and removed R4 to put the choke in so I wanted to check what the DVM said and compare it to what the meters said.
I'll tighten them up and see if that works then try and measure again.
Pioneer XCHM86. Vista Phono1+ w/ TEAC TN-400. Loth-X Ion 1 & Genesis II. WIP: Tubelab SE 300b
Old 2nd March 2017, 09:34 AM   #12
Atk1d is offline Atk1d  Canada
I too have the same meters for my see do they get wired the same?
Old 2nd March 2017, 03:57 PM   #13
Are the positions accurate. R18 and R29?
As R29 feeds the CCS chip.
Old 2nd March 2017, 04:01 PM   #14
colnago55 is offline colnago55  United States
The reason to have these meters on the TSE is that one needs to adjust the bias on the power tubes. My understanding is that the SSE was designed with fixed bias, so there is no need to adjust the bias.
I'd defer to others as to where they would go in the SSE circuit.
Old 2nd March 2017, 09:08 PM   #15
moggi1964's Avatar
That is my understanding colnago55
Old 3rd March 2017, 02:08 PM   #16
True the sse is pre biased , was hoping to add additional vintage look to a vintage style amp.
If anyone has managed to get these meters working on an sse please let me know.
Or if a suitable Vu meter would be better I would consider swapping these in.
Old 3rd March 2017, 02:25 PM   #17
w5jag is offline w5jag  United States
Try putting the meters in series with the cathode resistors of the power tubes, R27 and R17, and see if that works for you.
Win W5JAG
Old 3rd March 2017, 06:51 PM   #18
Thanks w5jag, I've tried this and the results were no sound.
Old 3rd March 2017, 09:55 PM   #19
moggi1964's Avatar
Never test with a Philip Glass album
Old 4th March 2017, 02:51 PM   #20
Later this afternoon, I'll take some pics showing how it's done.
Win W5JAG
Installing panel meters on an SEHide this!Advertise here!
Panel Meters craigtone Swap Meet 1 3rd February 2016 04:37 PM
installing amp/volt panel question jimmiegin Construction Tips 11 2nd April 2014 04:15 PM
panel meters CarlyBoy Parts 32 31st August 2009 08:32 AM
Adding panel meters to Simple SE? dogfish Tubelab 6 17th June 2009 04:23 PM
