Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 22nd December 2016, 04:56 PM   #21
awkwardbydesign is offline awkwardbydesign  England
Are you going to fit everything to the top plate? Even so, I would suggest having the bottom removable might be a good idea. My type 26 has NO bottom, for ease of access, but I lined the sides with aly foil for screening. Others have used copper foil, but I had the aly!
BTW, what is the circuit for this amp? I have only seen this thread; I assume it is in another thread?
Old 22nd December 2016, 05:27 PM   #22
mkane77g is offline mkane77g  United States
Always Learning
TSE & 45's
Top plate is 2 piece. Rear portion will have the iron bolted down minus choke which will go inside. All connection's will mount to the rear piece also. Front portion will have the tube cutouts and nothing else. this will be removable to make easy access to pcb.
Old 22nd December 2016, 07:56 PM   #23
Always Learning
TSE & 45's
7 hrs later and we have mucic. FM with a passive volume control. B+ is at 150v, B- 195v. Seems low. Should I change the value of C4? I'm tickled it's a music maker.
Old 22nd December 2016, 09:02 PM   #24
Always Learning
TSE & 45's
If I run the bias @ 20Ma I get 204v B- & 160v B+.
Old 22nd December 2016, 09:03 PM   #25
Always Learning
TSE & 45's
TSE running 45's
Old 22nd December 2016, 09:04 PM   #26
Always Learning
TSE & 45's
BTW I'm running 45's
Old 22nd December 2016, 09:05 PM   #27
Always Learning
TSE & 45's
rainman, sorry
Old 22nd December 2016, 09:20 PM   #28
Always Learning
TSE & 45's
Could the rectifier tube I'm using have anything to do with voltage's. Using 5r4's
Old 22nd December 2016, 09:24 PM   #29
BTW, if you are mounting Hammond chokes (which have a tendency to vibrate, I have been advised) to a metal plate, using these rubber mirror screw bushes can help isolate them. Available from your local glass merchant, probably. I find them very effective.
Old 22nd December 2016, 10:49 PM   #30
Always Learning
TSE & 45's
Thanks for that
TSE & 45'sHide this!Advertise here!
TSE 45 amp heat sink waltroman Tubelab 3 23rd November 2015 07:24 AM
Using TSE 45 to drive a GM70 (or other big power tube) cotdt Tubelab 3 15th January 2013 01:20 PM
TSE 45, how do I remove background noise cotdt Tubelab 14 8th November 2012 06:50 PM
45 TSE Checkout Fail Alan Hope Tubelab 13 17th January 2012 08:42 PM
45 TSE desired tube current? Acceptable B+? Alan Hope Tubelab 8 5th December 2011 12:07 PM
