Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 20th December 2016, 06:59 PM   #11
mkane77g is offline mkane77g  United States
Always Learning
TSE & 45's
And could you clue me in on where I check filament supply. At the tubes, but which pins?
Old 20th December 2016, 07:04 PM   #12
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
TSE & 45's
I believe that will have to be an electrolytic capacitor. Value should be close and voltage rating should be what is called for or higher.
http://www.evancotler.com
Old 20th December 2016, 07:09 PM   #13
Always Learning
TSE & 45's
Thanks you for your help. I have nothing close to 1500uf. Looks like a trip to RS. 2 hours round trip. Oh well.
Old 20th December 2016, 07:26 PM   #14
Always Learning
TSE & 45's
I flipped the 4700 electrolytic and no B-voltage. Think I killed it. Rat Shack has none.
Old 21st December 2016, 03:13 PM   #15
Always Learning
TSE & 45's
Pins 1&4
Old 21st December 2016, 10:20 PM   #16
Always Learning
TSE & 45's
B- is only 190v??????????
Old 22nd December 2016, 12:01 AM   #17
Always Learning
TSE & 45's
^^^^^^^^^^^^And B+ is about 25v. That's with one 5842 in place. Opinions please.
Old 22nd December 2016, 01:46 AM   #18
Always Learning
TSE & 45's
Ok, some progress I suppose. I now have 225v B+ and 190v B-. All tubes in but the 45's.
suppose I need to increase the value of C4
Old 22nd December 2016, 01:51 AM   #19
Always Learning
TSE & 45's
I'll bet my FREDS orientation is wrong.
Old 22nd December 2016, 02:54 PM   #20
Always Learning
TSE & 45's
That wasn't the reason voltage is low. With a rectifier tube in voltage is 200 both sides. Guess I'll run with it. Here's my second attempt at a base. My top plate has been shipped.
TSE & 45'sHide this!Advertise here!
TSE 45 amp heat sink waltroman Tubelab 3 23rd November 2015 07:24 AM
Using TSE 45 to drive a GM70 (or other big power tube) cotdt Tubelab 3 15th January 2013 01:20 PM
TSE 45, how do I remove background noise cotdt Tubelab 14 8th November 2012 06:50 PM
45 TSE Checkout Fail Alan Hope Tubelab 13 17th January 2012 08:42 PM
45 TSE desired tube current? Acceptable B+? Alan Hope Tubelab 8 5th December 2011 12:07 PM
Copyright ©1999-2017 diyAudio
