Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 31st July 2016, 09:44 PM   #1
hhibrownsbacker is offline hhibrownsbacker  United States
Default SSE - Thermal paste for CCS to heat shield??
I'm putting together a SSE board and was looking at the heat sinks for the CCS. Are you guys using thermal paste or anything for these. There's nothing in the build directions stating anything on it.
Old 31st July 2016, 10:59 PM   #2
rayma is offline rayma  United States
Heat sinks should be used with a thermal interface, such as a thin layer of thermal paste
under the right compression force. Otherwise, the thermal resistance of the sink to device case
increases, causing the junction temperature of the device to increase.
Old 1st August 2016, 05:53 AM   #3
tomchr is offline tomchr  Canada
tomchr's Avatar
+1 for the thermal goop. It actually makes a big difference. I use Wakefield 120 thermal grease. The "126" model would work as well. The difference is that the "126" is more tolerant to solvents used for PCB cleaning.
A less messy option is to use one of the silicone pads, such as Bergquist SilPad. They're pretty inexpensive and easy to work with.
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 5th August 2016, 12:45 PM   #4
Thanks again. Boards together, just waiting on OT.
SSE - Thermal paste for CCS to heat shield??Hide this!Advertise here!
Thermal paste waltroman Tubelab 2 15th October 2015 06:11 PM
Attaching Aluminum bar to heatsink - thermal paste or pads? john65b Solid State 52 3rd January 2015 09:43 AM
thermal paste smell? PreSapian Solid State 1 7th March 2011 03:15 PM
thermal paste? marko Car Audio 15 27th October 2010 08:42 PM
Thermal paste for amp heat sink? chipper Car Audio 3 1st September 2010 04:14 AM
