Simple SE Changing Feedback Switch While On - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 20th November 2015, 05:46 PM   #1
skidave is offline skidave  United States
skidave's Avatar
Default Simple SE Changing Feedback Switch While On
Wrapping up a Simple SE build.
Any issues with turning the feedback switch on / off while the unit is powered on? I read some posts here, but have not found a sentence that states 'I turned the feedback switch on/off while the unit was on playing music'. I'm assuming it is ok while powered on playing music.
I have other tube amps with a Triode / UL switch which I switch while on, but at low volume levels. No issues there.
I am building it with different cathode resistors connected in parallel via a switch. I'm not using a special make before brake switch, so I'm going on the assumption (again) that if I switch the switch quickly, there should be no issues. Thoughts?
Old 20th November 2015, 07:31 PM   #2
Just switch a parallel resistor to the higher value, for the lower value.
rgds, sreten.
There is nothing more practical than a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 20th November 2015, 11:12 PM   #3
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
It will be fine. The caps will hold the DC offset while the resistors are being swapped out.
Sent from my XT1575 using Tapatalk
Old 21st November 2015, 06:29 PM   #4
skidave's Avatar
Thanks. I'm using a 680 Ohm cathode resistor with others in parallel selected by a dual pole rotary switch.
I appreciate the feedback.
changing R1 value in SE amp yorga Tubes / Valves 5 2nd March 2014 02:47 PM
Changing 6SQ7 to 6SL7 in SE amp bereanbill Tubes / Valves 3 22nd May 2009 01:25 AM
Changing 300B Tubelab SE to accomidate 50 triodes Binaural Tubes / Valves 4 12th May 2009 03:56 AM
Simple SE cathode feedback... oldmanStrat Tubelab 9 1st May 2009 08:51 PM
Cathode feedback on the simple SE ixe13 Tubes / Valves 0 24th April 2009 12:52 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
