Problem with 10m45s - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 19th June 2015, 06:17 PM   #1
urmoo is offline urmoo  Estonia
urmoo's Avatar
Default Problem with 10m45s
Hi, My friend has a problem with SSE board and stabilizer (10m45s)- no output.
Everything seems to be OK, but the current one is second set of stabilizer and result is the same. Some measuremets as follows:
https://www.dropbox.com/s/p4kqgllrjr4coyi/n.jpg?dl=0
Any good idea what to check, measure? Thanks in advance!
Old 20th June 2015, 05:58 PM   #2
JP is offline JP  United States
JP's Avatar
Where did your friend get them? Lots of fakes out there.
"Show me on the doll where the aliens touched you." - SY
Old 20th June 2015, 07:24 PM   #3
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
The control pin is dragged down by the load. It won't work like that!
10M45 ... - Datasheet Search Engine Download
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 21st June 2015, 12:35 AM   #4
tubelab.com's Avatar
What???? There is nothing wrong with the circuit. It has been working perfectly for 8 years and hundreds of amp builds, SSE and TSE.
Unfortunately the most likely answer is fake parts or improper installation. There have been other builders who have received fake parts and all of them have been in Europe. This has been the usual reason for zero plate volts on the SSE or TSE.
It is also possible to install the part using the installation instructions for the wrong side of the board, SSE only. This usually results in high plate voltage.
You can test the board by replacing the 10M45 with a 18 to 22K ohm 2 watt resistor. This should make the amp play, but the results will not be optimum.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 21st June 2015, 09:10 AM   #5
urmoo's Avatar
Thank you for your answers! He got them from 2 different suppliers in Ebay, both European, so probably fakes. Resistor test makes SSE playing, so the board should be OK. Though the sound was not best possible, perhaps because of this resistor solution... or perhaps audio caps were fakes as well.
Old 23rd June 2015, 10:09 PM   #6
The resistor provides power to the 12AT7, but now the 12AT7 operates into less than a 30K load, which it doesn't like. This lowers the gain and increases the distortion. With a 10M45 the 12AT7 sees a 120K ohm load which it likes.
Old 8th July 2015, 08:20 PM   #7
humax is offline humax  Estonia
Hi George !
I found new stabilizers 10m45 from Ukraine and now is all ok. Tubelab SSE works well. Many thanks and well done George !
10M45S problem scott17 Tubes / Valves 42 12th February 2013 12:33 AM
10m45s Steven123 Tubelab 10 8th May 2011 11:39 AM
Ixys 10m45s theskintman Tubelab 0 31st August 2010 11:31 AM
Ixcp 10m45s Wombat 397 Tubes / Valves 14 4th September 2009 12:09 AM
Wtb; 10m45s Cobra2 Swap Meet 9 26th November 2008 05:17 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
