SSE sounds bad in UL - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 25th April 2015, 01:54 PM   #1
Default SSE sounds bad in UL
Sounds great in triode mode with cathode feedback, but ultralinear sounds terrible. Any ideas from those who have been down this road before? I'm using the big edcors and mullard KT88's.
Old 25th April 2015, 03:24 PM   #2
Please could you describe what you're hearing that is leading you to your conclusions?
I am not disagreeing with you, but am interested - my SSE has only been wired in triode mode as yet with EH KT88's and zero feedback.
Thanks,
Charlie
Old 25th April 2015, 03:50 PM   #3
The amp is certainly louder in UL, but distortion is unbearable even as less than half volume. It's so bad that it would make a good guitar amp!
Old 27th April 2015, 11:33 PM   #4
kevinkr's Avatar
Have you checked with an oscilloscope to see whether the amplifier is oscillating? (You'll come back and tell me that you don't have an oscilloscope - can you find someone who does?) Are you sure your cathode feedback is correctly phased?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th April 2015, 11:47 PM   #5
You are correct that I don't have a scope. I can borrow one from work. Not sure on the feedback phasing. Can you talk me through the scope checks?
Old 28th April 2015, 08:45 PM   #6
w5jag is offline w5jag  United States
That was the first thing I thought of.
I know when I had the Transcendars on my first SSE, and I was playing around with it in pentode, I could make it oscillate with the cathode feedback backwards. The oscillation was obvious, though - it squealed like a pig.
After awhile, I swapped out for 125 ESE's to take advantage of the different loads, and they hook up easy - just pick an unused secondary and connect it to the cathode feedback point on the board.
I have my low power SSE running 2E26's in UL and have not heard any unusual distortion in it with the small Edcors, but, I do not have the cathode feedback enabled. UL is enough feedback for me.
The cathode feedback seemed subtle to me - the 125 ESE's do benefit from it, but I would think with a better class of OPT's, it wouldn't add much.
Win W5JAG
Old 28th April 2015, 08:55 PM   #7
It will be more sensitive in UL than it would be in triode. What are you driving it with? Are you overdriving it?
Win W5JAG
Old 28th April 2015, 09:04 PM   #8
Driving it with a direct source DVD player.
Old 28th April 2015, 09:40 PM   #9
Have you tried it without the CFB enabled?
Win W5JAG
Old 28th April 2015, 09:49 PM   #10
No it's always been with CFB.
10w Transcendar SSE (non-UL) lordearl Tubelab 2 28th March 2015 02:07 AM
SSE pentode/triode/UL neomat Tubelab 7 22nd July 2012 02:58 PM
SSE/KT-88/Transcendar OPT: UL? CFB? Why? dagerman Tubelab 2 10th September 2011 04:17 PM
SSE triode/UL wiring help please Horsebox Tubelab 2 10th May 2011 06:36 PM
Check my SSE's Triode/UL and CFB Switch Connection Junior Tubelab 19 17th April 2010 02:58 AM
Copyright 1999-2017 diyAudio
