Voltage on rectifier pins 4 & 6 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 22nd April 2015, 12:48 AM   #1
Default Voltage on rectifier pins 4 & 6
Can anyone answer this for me?
I checked the Voltage between pins 4 & 6 and ground on my SSE. There were no tubes installed. I got around 190VAC. My trafo is 375-0-375. In Ty"s checkout guide her shows just over 400 V for the same secondaries.
I have installed 1n4007's onto the primaries as protection for the rectifier tube according to George's recommendations. If they're essentially blocking half the AC waveform, then wouldn't I expect about half the 375 V which would give me around 187 V???
I also used the 120v tap rather than the 115 volt tap. My AC typically sits around 116, so I assumed that conservative would be better, although it was more like 111 vac on Sunday. Thoughts?
Thanks,
Charlie
Old 22nd April 2015, 02:08 AM   #2
DUG is offline DUG  Canada
No, if I understand you correctly.
You are feeding a transformer with pulsed DC and expecting it to work properly?
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 22nd April 2015, 02:41 AM   #3
Sorry, I meant the HV secondaries !!!!
Charlie
Old 22nd April 2015, 02:53 AM   #4
I have installed 1n4007's onto the <secondaries> as protection for the rectifier tube according to George's recommendations. If they're essentially blocking half the AC waveform, then wouldn't I expect about half the 375 V which would give me around 187 V???
If you did not have filter capacitors and used a TRUE RMS voltmeter it would read half of the output voltage, yes 187V. I don't know how your voltmeter would react to halfwave rectified waveforms.
If it was still full wave rectified (from both sides of 375-0-375) then the TRUE RMS meter would read 375-0.6V and capacitors would hold the peak voltage at 1.414-375-0.6
In either case the peak would still be at 1.414*375-0.6 so any cap would hold the peak level it was charged up to.
Helpful?
Old 22nd April 2015, 03:01 AM   #5
Very helpful, thank-you. I am glad to know that sometimes my logic proves accurate. And I do not have a true rms meter.
Your wisdom is much appreciated.
Charlie
Voltage Doubler & Normal Full Wave Rectifier on Same Winding ballpencil Power Supplies 6 5th July 2014 12:23 PM
Damper rectifier tubes & voltage doubler jono1 Tubes / Valves 10 11th February 2012 05:05 PM
what pins to use solid rectifier for 5Y3 elementx Tubes / Valves 5 6th September 2007 09:12 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
