OK, I blew a fuse. Everything was playing fine, when I got a slight dip in volume then sound faded quietly and uneventfully into nothing.
I was using a 1 A slow blow fuse. I notice that folk tend to use higher values (around 2A).
Everything else seems fine. The amp is not hot, the chassis above the board is slightly warm, but could be from the tubes.
Any ideas?
Thanks,
Charlie
Any ideas?
Thanks,
Charlie
