Transformer Voltages
I get all my work done checked by a friend who is, before powering up. This is done at his place.
very good practice, even today i am scared stiff when powering up my freshly built tube amps for the first time, even if i know that i have done everything right.....
a lamp tester in series with the mains really comes in handy next time you decide to do it yourself...
btw, a couple of years ago i did two of these 2A3 amps, biased equally at 250volts plate and 60mA....the Shuguangs biased identically spot on...
Wayne,
Through double checking noticed that Edcor XPWR 007 does not have a ceter tap on the 6.3v rail.
A center tap for 6.3 is required for 2A3 tubes...
Only option I found for 6 amp 6.3v rail with center tap is:
https://www.edcorusa.com/xpwr139
But this does not have a 5V tap. So you will need to order another small transformer for the rectifier:
https://www.edcorusa.com/lvp5-3-240
the 2A3 requires a 2.5 volts filament, http://tubedata.milbert.com/sheets/127/2/2A3.pdf
AJT,
Greetings! Thanks for joining the thread.
If you have the time can you please take a look at George's recommendation under 2A3 Tubes on this page?
Tubes and Applications | Tubelab
The filament current for two 2A3 tubes is 5 amps. A power transformer with at least 6 Amp capability on the 6.3 volt winding is required. A center tap on the 6.3 volt winding is required. The filament regulator IC will require a supplemental heat sink with 2A3’s. I use the heat sink from an old Pentium IC.
My understanding is that he has on-board power regulation for filaments, and thus 6.3v with CT @ 6A is required for the TSE with 2A3.
The 5v low voltage transformer I suggested was for the rectifier tube (5AR4).
Appreciate your inputs on this.
ah, George is a very capable designer, i learned many of the things i know from him...
if you read the text, a regulator was used to convert the 6.3volts ac to dc voltage and regulated to supply the required voltage...
what i posted is that if you have a traffo with a 2.5v ac with center tap, then you can use it, the reason he used the 6.3volt is because 2.5 volt filaments are not commonplace today, in my amps, the power traffo i used was my own design although i asked another winder to build it for me...
btw, using just ac on the filaments, those amps that i built were totally hum free, those amps were used to drive horns, and any noise coming from the amp is magnified...
Hi Zman
They offered to do a custom centre tap - for an additional $120.
Cost of customization... :(
Will Edcor help you with changing the order? After all - items are "built to order"?
Change order on power transformer and go with this PT - has a 6.3v with CT @ 6A (but no 5v tap)
For the 5V tap (rectifier connection), take an additional low voltage PT:
Will save some cost (~ US $100), add slight bit more work in wiring.
George documented (either on his site or here) that he found something wrong with the sound of DHTs with AC filaments. He found that while you could null out the fundamental, the harmonics remained. From what he wrote, this is the reason he chose to use DC for the filaments.
oh, i have no reason to doubt that.....
what i am saying is, i used 2.5 volts ac on the filaments, it worked for me,
the owner of the amp is happy, i am happy for him...
Zia
I am a bit confused
Do I get a power transformer - https://www.edcorusa.com/xpwr139
Yes, one unit
No. For 2A3 more suitable is: https://www.edcorusa.com/gxse15-8-2_5k
2 units.
and LPV53-240 for the rectifier?
Yes, LVP5-3-240 for rectifier
1 unit
So, total 4 transformers.
1 x Power Transformer XPWR139
2 x Ouptput Transformer GXSE15-8-2.5K
1 x Low voltage power transformer LVP5-3-240
Have you also ordered the choke?
Thank you again for your advice. I have passed this to Edcor and i will buy the choke you found in Australia... and post the results!
Wayne,
Can you please check the link for the choke I had sent earlier and check for the shipping charges? Element14 ships certain items from the US/UK also, so it will be good to check the shipping.
