Advantage of placing Tubes on the board
The boards are plenty strong enough and have enough mounting holes to support removing/installing tubes as needed/wanted. George designed the boards to be built either way. I think you are good with anyway you like to build it. It's harder to cut the tube base holes exact for mounting PCB under the top plate but other than that it's pretty easy. Painting takes more time!!
Bob
