Toroidal PT for SE - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 20th August 2014, 11:49 PM   #1
Pauly is offline Pauly  United States
Pauly's Avatar
Default Toroidal PT for SE
Hi
I came a cross and interesting thread re using a toroidal PT for an SE board
Tubelab SE - alternate power transformer
Due to space (and cost) considerations I would like to use a toroid also. Has anybody done anything in that vein since the link was posted back in 2009? I don't want to be unwinding transformers if I don't have to, but I will probably use two (or three) transformers if need be
Paul
Old 21st August 2014, 12:03 AM   #2
Sodacose's Avatar
I built an RH84 design with a toroidal PT (and a voltage doubler to boot). Came out sounding great and not a hint of hum.
See build thread here.
I definitely plan on using toroids in the future as well. One of the only issues I've encountered (at least with Antek toroids) is that they don't have a 5V heater for tube rectifiers.
I think my ear just popped a boner.
Old 21st August 2014, 12:58 AM   #3
Pauly's Avatar
Indeed, I don't want to start unwinding trans coils just yet.
I was thinking of going solid state rectifier (I have a box full of MUR860 laying about) but I'm not sure how to achieve a + 300V(ish) B+ AND a -150V(ish) off the same secondary.
Paul
Old 22nd August 2014, 02:26 PM   #4
Unwinding toroid isn't that hard. It's a fun learning experience. If the space is an issue, that's more reason to use just 1 transformer.
Old 22nd August 2014, 02:53 PM   #5
Pauly's Avatar
A "fun learning experience" is getting a massage in Chinatown. :-)
I'm a notoriously slow builder (and I mean sloooooow), and I am building a Bottlehead Smash and two line conditioners at the same time, so I cannot be putting extra stuff in my path. I also don't know how to measure the voltages to figure out when I've unwound enough to get to 5v. (how do you measure btw?)
I'm actually thinking of going solid state rectifying on the HT side and in so doing eliminating the need for a 5v secondary.
Cleet.
Old 23rd August 2014, 06:40 AM   #6
zman01 is offline zman01  Bangladesh
How much space and $$ will the toroid save you?
A popular choice for TSE builders - should not be much higher in cost vs a good toroid:
https://www.edcorusa.com/search?q=xpwr131
Old 24th August 2014, 12:26 AM   #7
Pauly's Avatar
Yep, bought a xpwr131. Too much hassle otherwise.
Paul
Old 27th August 2014, 01:14 PM   #8
Hi Paul,
How is the project going? Have you decided which OPT to get?
Old 27th August 2014, 01:49 PM   #9
osscar is offline osscar  Latvia
osscar's Avatar
hi,
I also can share my experience with toro PT for SE - for may 6C33C (you already know that this babes loves to eat current a lot ) I use two 200W transformers - one per channel. I put them on the L-shaped steel angle and insulate from chassis with rubber O-rings under screws. No vibration or hum or buzz - then put over them 130x130x130 mm transformer cover.
They are Indel (poland) transformers - specifically designed for tube amps with screening and will not cost you a kidney
If time is money then I'm out of time
Old 28th August 2014, 12:20 PM   #10
Pauly's Avatar
Hi Paul,
Hi Zman
Still waiting on parts. As a slow builder (I travel a lot and will be in Africa most of October and Novemebr) I am not planning to be finished before lets say mid December.
I ordered the James Audio transformers. Apart from being very aesthetically pleasing to me, the fact that I can can configure for either 2.5K or 3.5K loads and the 4 & 8 ohm taps was a big draw card. I think I'll put the primary inputs on a switch so I can toggle between 2.5K and 3.5K impedence and let my ear decide which is the better.
Paul
Can i use this PT with Tubelab SE? Magnetmaz Tubelab 4 22nd February 2014 02:41 AM
Putting the Simple SE back together - blown PT - Flashing Rectifier cjkpkg Tubelab 13 15th October 2008 01:27 PM
Toroidal SE transformers zogu Tubes / Valves 22 28th February 2007 09:28 PM
toroidal SE output transformer noyan Parts 10 11th July 2004 10:41 PM
Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) Rixsta Pass Labs 10 23rd April 2004 03:41 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
