Tubelab sse choke input 6v6 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 19th August 2014, 01:04 AM   #1
Ritchie is offline Ritchie  Canada
Default Tubelab sse choke input 6v6
I am in the process of building a tubelab sse. Ordered edcor iron anticipating the use of el34's/6l6 etc.
Have now decided I would like to try the 6v6. So I will have to go with a choke input filter to lower the B+.
Was hoping someone could tell me if I am going to need a choke specifically designed for input duty or if the regular edcor choke will work here?
Thanks,
Ritchie
Old 19th August 2014, 01:23 PM   #2
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I've used regular chokes with a small input cap (1uF - 4uF) to adjust the output voltage. Technically it is a CLC filter, but the first cap is so small that it apporaches an LC filter. I use film caps for the first cap, as they are good at handeling the ripple current and voltage.
Old 19th August 2014, 02:09 PM   #3
Thanks, I'll give that a try. That will also allow me to get the B+ close to desired.
Speakers for Tubelab SSE Sgrilli AD Tubelab 7 25th October 2013 01:54 PM
TubeLab SSE choke / component choice? normaldotcom Tubelab 10 5th October 2013 02:49 AM
Input / source selector for Tubelab SSE Sgrilli AD Tubelab 1 27th February 2013 01:27 AM
7062 in Tubelab sse? kkcinc Tubelab 0 3rd December 2011 02:50 PM
Tubelab SSE measurements budmaestro Tubelab 8 24th June 2009 11:41 PM
Copyright 1999-2017 diyAudio
