I take it that you're a gun lover?
How about this: http://www.mif.pg.gda.pl/homepages/frank/sheets/021/4/45.pdf
In my house it's called a .45, period.I take it that you're a gun lover?
I think he was just posing a rhetorical question while helping you with
information about your question about the tube.
45 tube sizes vary
... older 45s seem to have a standard size, but my TJ 45/n are actually too big for the TSE board, and touch each other. This does not seem to affect the sound, but is not ideal and at some stage I will have to put some tube holders on short leads so I can position the tubes an acceptable distance apart.
My response was tongue-in-cheek, hence the use the word of "period" following ".45" which should not have had a period.
Hi Alan
I have not received my board yet but I was thinking I may lay the tubes on their side to make things fit. Your comments is making me think that laying them on their side may be beneficial for more than just the height restriction.
Paul
Hi Alan
Paul
Put them out where they can be appreciated for their place in the history of Radio.
Very nice woodwork...
Nice looking amp you got there Bill
I may build a second and reverse the board or simply wire to wire my own layout, so I can build a more "traditional" looking tube amp. First cut I just want to get it to work.
I'm a newbie re 2A3 and 45 tubes, so I'd like to hear what the brouhaha is all about.
The amp shown is not the Tubelab SE but rather a Simple SE I built under the tutelage of Steve Brown long before I heard of George Anderson.
My Tubelab Simple SE withg Gold Lion KT-88s is built in the traditional Hammond box and sounds a lot better than it looks.
I have to say thoughs, that the 45 amp does also; get past the fancy antique radio-type chassis I built and it's dual mono from the power transformer with all Magnequest iron. Yowzah!
- More Vendors...
- Tubelab
- Physical dimensions of a .45 tube
