Edcor CXSE CFB wiring. - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 9th July 2014, 08:50 PM   #1
YashN is offline YashN  Canada
Default Edcor CXSE CFB wiring.
Has anyone with Edcor CXSE25-8-5K used CFB (cathode feedback)?
If so, could you please tell me if the Edcor OPT wires must be inverted on to the PCB?
Thanks.
Old 10th July 2014, 11:51 AM   #2
Try it both ways and report back .....
Bob
Old 10th July 2014, 05:59 PM   #3
Tried it the inverted way, but can only report a blown fuse on power up for now...
Old 10th July 2014, 06:00 PM   #4
The thing is, I was looking for somebody who already has implemented it with the same Edcor, so that I avoid having to try both ways.
Old 10th July 2014, 07:15 PM   #5
I never tried the inverted way always used the Edcors as indicated on the schematic with good result, so I never tried it the other way around. I think the transformers with the issue are Hammond but don't quote me on that.
Bob
Old 10th July 2014, 10:18 PM   #6
I don't think it's an issue per se, just a question of how the wiring is done in the transformer so that you actually get cathode feedback in the proper phase.
Guess I'll have to try both ways and choose the lowest volume as George recommends if nobody did it before.
But for now, it seems I'm stuck, Pin 2 of the 12AT7 misbehaves, probably C10 or some other thing is fried...
Old 11th July 2014, 09:56 PM   #7
Looks like inverted works for me (George's diagram is inverted). I tried using it non inverted, but then a type of high-pitched screech started to build up, probably oscillation as the feedback was positive rather than negative.
With inverted, there's no screech.
F/S SimpleSE Edcor CXSE chassis etc nvrgdenuf Swap Meet 1 2nd August 2009 12:12 AM
F/S SimpleSE w/ Edcor CXSE opt nvrgdenuf Swap Meet 0 11th July 2009 08:40 PM
SimpleSE parts/Edcor GXSE/CXSE nvrgdenuf Swap Meet 5 11th July 2009 08:33 PM
FS: Pair of Edcor CXSE Output Irons N1ESE Swap Meet 2 13th December 2008 11:55 AM
SimpleSE / Edcor CXSE OPT Zap Tubes / Valves 33 23rd January 2008 02:51 AM
Copyright 1999-2017 diyAudio
