SSE first build, caps and other questions. - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 19th June 2014, 05:53 PM   #11
YashN is offline YashN  Canada
Default Initial chassis priming, painting and sanding and motor run cap.
Originally Posted by bbakertx View Post
If only they made a square/rectangle one for IEC inlets.....
Haha!
What I'll do for the IEC hole is use a medium thickness wood plate and drill several holes along the lines, then sand them until the IEC plug fits. The IEC plug, filter and fuse are salvaged from an old synthesizer.
Question: is the motor run cap necessary or optional?
Pre-primer sanding (you can probably discern a little layer of epoxy around the holes drilled for the transformer wires to prevent abrasion of the insulators):
Some primer after hammering out most of the kinks:
Several coats of primer:
Some good results with primer sanding on the lower left:
Old 19th June 2014, 06:22 PM   #12
+1 on the stepped drill bit for round chassis holes.
I bought a Milwaukee 2-size set for about $60 and have had great results.
Greenlee makes a punch for that but it's not cheap.
Bob
Old 19th June 2014, 06:24 PM   #13
For making such holes a hole punch is very good.
Old 19th June 2014, 08:59 PM   #14
Does anyone know where I can source the sockets and tubes as well as the caps in one place, preferably from Canada?
Old 19th June 2014, 11:50 PM   #15
Youbetcha...
Parts ConneXion - The authority on hi-fi DIY parts and components
They should have just about everything you need. I'd use them cept they are in .... ahem Canada Eh?
Bob
Old 20th June 2014, 03:50 PM   #16
Hey Bob, I was just looking at them, built a temporary shopping list with 4 sockets, choosing the Teflon-composite silver PCB mounts, and the total is $33. Things add up quickly!
I think they only have expensive tubes, so I may have to get the sockets from them and source the tubes elsewhere for a more affordable price.
Old 20th June 2014, 06:29 PM   #17
Right now Parts Connection have a 20% off almost everything including vacuum tubes.
They usually have this offer twice per year. These are the times when I get my
vacuum tubes from them. I have purchased several times over the past few years.
I find that even with the HST tax it is still cheaper than ordering from the USA.
I'm referring to tubes like Electro Harmonix, Sovtek, and reissue tubes like Tung Sol,
Gold Lion, Mullard and others.
The 20% off goes for other stuff as well - resistors, capacitors, connectors, etc.
Old 20th June 2014, 06:54 PM   #18
ranhaber's Avatar
Don't what kind of tubes you are looking for but you can try the sale here
Sonic Craft Specials
Old 20th June 2014, 09:15 PM   #19
I use the cheap Chinese ceramic versions for $2/pc they work fine. There's not going to be a sonic different between a $2 socket and a $10 gold pin ...
For tubes which tube are you thinking about using?? For driver I'd get an old stock 12AT7 - I don't like the sound of the reproduction (12AT7) tubes at all. The old stock sound very good and readily available look for Sylvania they should be in expensive and sound good. You can upgrade them later if you want to roll tubes in. Trust me on the new stock driver tubes they will make the amp sound like crap.
Bob
Old 21st June 2014, 12:15 AM   #20
Hopefully some affordable 6L6GC, and then I'll also need a rectifier tube and another one.
My finally finished tubelab SSE build!!....Some follow up questions djherse Tubelab 16 2nd April 2014 05:03 AM
SSE build ?? bobrown14 Tubelab 6 8th December 2013 10:22 PM
Novice SSE build the trooper Tubelab 35 11th April 2013 10:42 PM
New user with sse questions. ihatesissycars Tubelab 4 11th April 2012 02:59 AM
Some more beginners questions about SSE urmoo Tubelab 16 12th February 2010 06:19 PM
Copyright 1999-2017 diyAudio
