Newb question: Building my first amp using Edcor cxse25-8-5k opt's. George's wiring diagrams show red, dark blue and light blue wires on one side and black and green on the other. My edcors are (respectively) blue, white w blue, and red on one side and yellow and white on other.
Apologies if this was addressed on the Tubelab site or in the archives, but have searched with no luck- Thanks.
Here ya go:
Inputs
Blue wire = Plate
blue-white = UL tap
red = B+
output side
White = common (negative speaker terminal (not the ground tab)
Yellow = 8 Ohms (positive speaker terminal)
I don't remember if my positive output to speaker was yellow or not but that should be fairly easy to sort out.
ask questions - easier than fixing a screw up
Bob
Inputs
Blue wire = Plate
blue-white = UL tap
red = B+
output side
Bob
Maybe this will help.....
- More Vendors...
- Tubelab
- OPT connections with SSE
