Fuses in SE - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 7th May 2014, 04:10 PM   #1
moggi1964's Avatar
Default Fuses in SE
Where have you installed fuses in your SE?
I'll have a slo-blo in the IEC but was wondering if there is value in in-line fusing other components and if so which and where?
First power-up planned for Sunday 17th May so just making sure I have everything in place for the checkout.
Magnavox 185 amp w/ Vista Phono1+ w/ Dual 1219 N.E.A.R 80 & Emotiva XDA2. WIP: Tubelab SE 300b
Old 8th May 2014, 01:16 PM   #2
You can fuse the center tap of the secondary HT right behind the CL-90, that will protect your power transformer. There's other ways to do it but that's how I do it.
Bob
Old 8th May 2014, 01:39 PM   #3
moggi1964's Avatar
Bob, you use the same type and amperage as the IEC - slo-blo 1.5/2amp?
Thanks.
Old 8th May 2014, 03:49 PM   #4
Thanks.
I use 3-5 amp slo-blow, you could try the 1.5A fuse but the CT on the power transformer is seeing the full output of the secondary 100% of the time. You could add up the current being used and size the fuse appropriately but I just use a 3-5 amp fuse whatever is in my drawer. It's just gonna save the PT in the unlikely event of a catastrophic failure. The IEC fuse is going to save your home in the unlikely event of a catastrophic failure. Catastrophic failure = amp turns into toaster oven!! VERY unlikely but I've had it happen to me. The diodes added to the board on the last update TCOs that tho. I put the fuse there as a mater of course/habit more than anything else.
Bob
Old 9th May 2014, 05:46 PM   #5
moggi1964's Avatar
Excellent!
Thanks for the explanation and suggestion.
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 02:51 AM
Small, high quality 15v PS to drive an SE/SE Wire MisterRogers Power Supplies 0 13th June 2012 02:36 PM
OPC’s The WIRE – Latest Generation - PCBs for sale (4x BAL-SE, 1x SE-SE, 1x PSU KIT) fualcr Swap Meet 0 16th February 2012 12:39 AM
Simple SE blowing fuses HEADinaJAR Tubes / Valves 53 10th May 2009 03:46 PM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 06:00 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
