Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 29th June 2014, 07:14 PM   #61
Art M is offline Art M  United States
Sparks generate Very wideband RF signals easily showing symptoms on many pieces of equipment.
Old 29th June 2014, 07:35 PM   #62
mudchute is offline mudchute  United Kingdom
Its definately not the mains, its a brand new house and the same happened in the previous victorian era house we occupied. The bit that concerns me is that it only happens with the amp on and after its been on a while.
Old 30th June 2014, 12:56 AM   #63
bobrown14 is offline bobrown14  United States
Try a new power strip, and add the X2 cap to your mains in on the amp to protect your audio gear. New house doesn't mean good wiring, just means new f'd-up wiring. Since this was happening with your old home and now the new home, you brought the culprit with you. Probably not the amp. Try a NEW power strip, pretty easy there. I'd not have my tv on that same house circuit - could be the power supply in the TV getting ready to take a crap. The power supply in TVs are "switched" and they generate a lot of line noise which is why I suggested a X2 cap inside the amp to rid that off the mains voltage going into your amp. The TV is probably the culprit - just unplug it (psu on the TV is on all the time even tho the TV is off) - unplugging the TV should give you relief.
Bob
Old 13th July 2014, 08:08 PM   #64
I hate to say it but I replaced the at7 again and the whoosh/hiss noise has gone. I've since just left it well alone and just enjoyed it.
aka Gavin.
SSE hissing problem.Hide this!Advertise here!
static 'hissing' noise problem hakentt Car Audio 20 14th April 2014 07:22 PM
Harman Kardon A-401 Treble Hissing Problem Alarudin Solid State 0 16th January 2014 01:38 PM
possible problem with sse royd55 Tubelab 1 19th July 2010 04:16 PM
possible problem with my sse royd55 Tubelab 4 1st March 2010 05:15 PM
lanzar 546-- problem with hissing noise over one channel jmg Car Audio 3 31st January 2008 05:00 PM
Copyright ©1999-2017 diyAudio
