Hi all,
I built a SSE and have been using a Sylvania fat bottle 5AR4 rectifier tube in it. I picked it up used at an antique radio flea market in a PA with two RCA 6L6GC’s. I used it for about 7-8 months. I then picked up new on eBay one of the Philips 5V4GA’s which is supposedly a military mislabeled Sylvania fat bottle 5AR4 and started using that. Now about 8 months later I noticed that the getter on the mislabeled Phillips seems to be flaking off. See picture. I took out the old Sylvania and noticed that the getter is also flaking on it too.
Could this be a problem with Sylvania’s in general or something with my SSE? When running the tube doesn’t appear to run hot. I used the standard Allied 6K7VG transformer, C1 and C2 are both external motor run caps, I also use the Allied choke. All the voltages seemed to check out fine the last time I checked them. The amp is running fine and sounds great.
So is the flaking of the getters a problem? If so could it just be the tubes or is the SSE amp tearing them up? Any info would be appreciated.
Thanks,
Mike
Thanks,
Mike
