Confirming umbilical connector choice
These look suitable for an umbilical for the Edcor 131 power supply but I wanted to check with the knowledgeable. It will only be the PS on the umbilical, everything else is staying PCB side.
[link
[Link
Just need to find some 9 conductor 600V rated wire; a rummage around in the basement to begin with then off to Google :)
JP
Joined 2011
I wouldn't advise running solid core in an umbilical - it's not made for continual flexing and may be prone to breaking, depending how much you move the umbilical.
Also, IMO, and if you believe in exotic materials more power to you, but there's no advantage to this wire over standard $0.18/ft 600V stranded.
Another question :)
Given the individual wires are only using a Teflon coating should I twist them around each other and then apply a shielded braid over them all?
Does the twisting matter in this application?
Does the shielded braid matter or would unshielded be fine?
So many questions; so little money left :)
FWIW, the Bulgin Buccaneer connectors linked in your first post are only rated for 150VAC/VDC.......not really enough for a 360V transformer.
The Amphenol connectors are very burly (metal!); another good choice are Amp CPC series (circular plastic connectors), many of these have a 600V dielectric rating.
OK, here we go:
If I get teflon coated 18 gauge copper for ALL the connections form the PS (600V certified), should I twist pairs and then surround the whole bunch (including the ground wire) with a SHIELDED or NON SHIELDED braid (or some other combination)?
I have 14 pins to play with on the connectors so I figure I can run the ground down the center and then twist the various AC wires from my Edcor 131 to create a small number of twisted pairs plus a ground.
