I like copper, I can't help myself - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 22nd February 2014, 04:32 PM   #11
By the time you go through all the coating and etc. you might as well just paint the "copper" paint on whatever other material you build it out of.
Here's an extreme version of copper love.
Old 22nd February 2014, 04:46 PM   #12
moggi1964's Avatar
But in your heart you would know
TEAC RH 500 Amplifier Vista Phono1+ w/ TEAC TN-400. Loth-X Ion 1 BS & Emotiva XDA2. WIP: Tubelab SE 300b
Old 26th February 2014, 03:19 AM   #13
moggi1964's Avatar
Copper arrived today.
The pretty side is covered in a peal off plastic and will stay covered for now. Looks good on the rough side and feels strong.
This is going to be nice to work with I think.
Old 28th February 2014, 03:02 PM   #14
boywonder's Avatar
You can also use contact cement to bond in thin sheet of copper to a thicker sheet of aluminum. Beauty, strength and stiffness all in one package....maybe even a little bit of constrained layer damping as well.
Old 28th February 2014, 05:20 PM   #15
I've got an idea for that, why not use wood and just paint copper color.
Old 28th February 2014, 05:47 PM   #16
Copper is so Awesome!!!!
I was planning to do the front panel of my custom stereo with a 1/4" bar of copper.
And I have made some ESL stators made with Copper Plated TIG Rod and they will be coated with some clear acrylic!!
I have posted pictures of them here before.
Keep on DIYin' !!!!
jer
Old 28th February 2014, 06:13 PM   #17
boywonder's Avatar
Flammability for one thing.....I like to keep the combustibles away from the heat and electronics where possible.....although I've certainly been guilty of making fancy wood chassis....
Old 28th February 2014, 07:14 PM   #18
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by moggi1964 View Post
... need to find a place locally to do the coating work to ensure it is done well ...
I do not like it shiny, but prefer the red color when aged naturally
just polish it once, and stat's it
only problem is if scratches occur during construction
sometimes we know very little, and sometimes we know too much
Old 28th February 2014, 11:12 PM   #19
moggi1964's Avatar
Tinitus; won't it get green if it isn't coated?
Boywonder, I have the option to do that if the copper looks like ti won't be up to the job. I have moved the PS off of the main build so that takes some of the weight away.
It will be mounted in the Hammond all walnut surround case so mounting the choke and OT's near the edges/corners will also share the weight.
Jer, you got it
WTB: Harmonic Tech Cyber-Link Copper or Digital Copper cable reaction Swap Meet 1 2nd July 2010 11:50 AM
Copper Foil a.wayne Planars & Exotics 4 23rd February 2010 11:08 PM
Copper going away at 350 ? Bernhard Parts 8 12th May 2008 08:28 PM
Copper heatsink tweak - Thermaltake Copper Heatsinks Ruach Digital Source 16 23rd September 2006 11:59 PM
All copper heatsinks? Dominick22 Chip Amps 40 17th February 2006 07:55 AM
Copyright 1999-2017 diyAudio
