Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 22nd February 2014, 12:55 AM   #1
moggi1964 is offline moggi1964  England
moggi1964's Avatar
Default I like copper, I can't help myself
So what about this as a top plate:
2.4mm thick Copper 101 101 Copper (available in Plate, Round, Sheet, Square, Tube)
ASSUMING it is up to the job of handling the weight; any other issues with using copper as a top plate?
Thanks.
TEAC RH 500 Amplifier Vista Phono1+ w/ TEAC TN-400. Loth-X Ion 1 BS & Emotiva XDA2. WIP: Tubelab SE 300b
Old 22nd February 2014, 01:01 AM   #2
kevinkr's Avatar
It's a perfectly valid choice, just make sure it is thick enough to handle the weight. It's a bit hard to work because it is so soft.. Clear coat it once you have done all of the prep work and it is nicely polished, and meticulously cleaned to remove finger acids. Do several coats to assure that pin holes are not a problem in the future. Make sure not to handle the chassis plate at all after cleaning - otherwise the finger prints will magically appear under the finish a few years later. Bake and then allow to harden for a week or so before you assemble the amp.
I had a line of commercial gear with all copper chassis, and some of the chassis have held up well and others have not. Finger prints are a real problem..
Done right it will be beautiful..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 22nd February 2014, 01:06 AM   #3
moggi1964's Avatar
Thanks Kevinkr; need to find a place locally to do the coating work to ensure it is done well as I am clumsy and clueless That's what makes doing a DIY amp so interesting for me - lol
Old 22nd February 2014, 01:09 AM   #4
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
I have spray equipment....
Evan
http://www.evancotler.com
Old 22nd February 2014, 01:14 AM   #5
moggi1964's Avatar
Evan
Sent you a PM
Old 22nd February 2014, 02:25 AM   #6
For an extra about $20.00 you can go to 1/8" thick. I would guess this to be strong enough but I am just guessing. You could also think about a layer of aluminum under the copper for strength.
Old 22nd February 2014, 02:58 AM   #7
moggi1964's Avatar
Hmm, I wrote and, I thought, posted a response but it seems not to be here.
Anyway, I was concerned about the weight of the thicker stuff (it's already 4.3 pounds) and I figure I can brace it if necessary. Anyway, it's ordered so I guess we will find out, eh
A big thank you to Evan for offering some assistance on this part of my project.
Old 22nd February 2014, 04:16 AM   #8
ade99 is offline ade99  United Kingdom
get all your conductors nice and thin, like you would with girls!
Old 22nd February 2014, 06:14 AM   #9
tomchr is online now tomchr  Canada
tomchr's Avatar
I seem to recall a couple of amps in the Tubes Picture Gallery built with what appeared to be diamond plate in copper. I don't care for the diamond plate myself, but copper - if finished correctly - can look stunning. As Kevin mentioned already, finger prints and oxidation is a real issue. I would have the plate professionally polished, sealed, and clear coated if I were you (no offense to Evan).
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 22nd February 2014, 07:32 AM   #10
none taken
I like copper, I can't help myselfHide this!Advertise here!
WTB: Harmonic Tech Cyber-Link Copper or Digital Copper cable reaction Swap Meet 1 2nd July 2010 10:50 AM
Copper Foil a.wayne Planars & Exotics 4 23rd February 2010 10:08 PM
Copper going away at 350 ? Bernhard Parts 8 12th May 2008 07:28 PM
Copper heatsink tweak - Thermaltake Copper Heatsinks Ruach Digital Source 16 23rd September 2006 10:59 PM
All copper heatsinks? Dominick22 Chip Amps 40 17th February 2006 06:55 AM
Copyright ©1999-2017 diyAudio
