Can i use this PT with Tubelab SE? Can i use this PT with Tubelab SE? - diyAudio
Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 21st February 2014, 04:22 PM   #1
Magnetmaz is offline Magnetmaz  United States
Magnetmaz's Avatar
Send a message via AIM to Magnetmaz
Default Can i use this PT with Tubelab SE?
I've got a really nice, in the original box / unused Chicago PSR-85 power transformer that i'd like to use with the Tubelab SE project with #45 tubes. It's probably from the 1950's / 1960's.
It's got the 5V @ 2A and 6.3V CT @3A no problem.
But, the HT is 440-0-440 @85ma, (which it says on the box is 325 DC with a 5Y3 or equivalent) which is above the spec of "540 or 550 VCT at 125mA"
Will there be too much B+ after rectification for this circuit?
Should i use this thing or save it for another project?
Old 21st February 2014, 08:01 PM   #2
Magnetmaz's Avatar
additionally, i have a slew of NOS vintage rectifiers at my disposal... 83's, 5V4, 5U4, 5Y3, 5Y4. What if i used one of those with more of a voltage drop on it ( more than the GZ34 / 5AR4) ? That might bring it down to a more suitable level.
I'll just have to wire a standby switch or some sort of soft-start circuit to protect these globe 45 beauties i have!!
Old 22nd February 2014, 12:01 AM   #3
moggi1964 is offline moggi1964  England
moggi1964's Avatar
Help will be along. I'm clueless but figured I would make sure you stay near the top
TEAC RH 500 Amplifier Vista Phono1+ w/ TEAC TN-400. Loth-X Ion 1 BS & Emotiva XDA2. WIP: Tubelab SE 300b
Old 22nd February 2014, 01:34 AM   #4
Magnetmaz's Avatar
I think it's going to be too much voltage. Going to have to source a smaller one. Shame because this transformer is potted and pretty and I got it cheap
Old 22nd February 2014, 02:41 AM   #5
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
440-0-440 is 880 volts CT and you need about 550 volts....yes it's too much voltage. The 325 DC they are quoting is with a choke input filter which will not work with the negative bias circuit. You will have about 500 volts of negative bias.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Can i use this PT with Tubelab SE?Hide this!Advertise here!
Tubelab SE zxx222 Tubelab 172 4th September 2016 12:53 PM
Tubelab SE vs Simple SE Pez Tubelab 25 29th October 2011 02:16 AM
Need Help with Tubelab SE lth1 Tubelab 9 1st October 2010 09:06 PM
Edcor (O)PT vs tubelab's color codes? Divad89 Tubelab 11 6th September 2010 04:07 AM
Putting the Simple SE back together - blown PT - Flashing Rectifier cjkpkg Tubelab 13 15th October 2008 01:27 PM
Copyright ©1999-2017 diyAudio
