Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 18th February 2014, 12:43 AM   #1
Guarnera is offline Guarnera  United States
Default TSE C6?
In the parts list for the TSE C6 is called out as 47uf. On the schematic it shows it as 100uf. Which is it? I'm using 300B output tubes, if that helps. Thank you all very much.
Old 18th February 2014, 03:01 PM   #2
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Either will work, just make sure it fits in the board. My early amps used a B+ in the 320 volt range and I built them with 100 uF 350 volt caps. The later amps used 360 to 375 volts which required a 450 volt cap. Some 100 uF 450 volt caps are too large to fit in the PC board. The tall skinny ones are OK. The lead spacing is the issue, but I am not at home now and I don't remember exactly what the correct spacing should be.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 19th February 2014, 03:55 PM   #3
acceler8 is offline acceler8  United States
I have a 300B TSE, and am using a 47uf cap for C6 (digikey part P5951-ND) with no trouble. It fits the PCB exactly.
TSE C6?Hide this!Advertise here!
TSE input jrobson Tubelab 7 9th December 2012 04:33 PM
Looking for a project with car speakers ( DLS C6 ) Trileru Everything Else 2 19th August 2012 06:47 PM
TSE help evanc Tubelab 2 12th June 2012 10:14 AM
Zen 9 Cap C6 and C7 Question vdi_nenna Pass Labs 3 20th August 2011 07:23 PM
PSW-D110 C6 cap metaldrumer Solid State 1 24th November 2010 06:20 AM
