Attenuator - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 18th February 2014, 10:50 PM   #11
JP is offline JP  United States
JP's Avatar
Originally Posted by tubelab.com View Post
The TSE uses a 5842 tube which has a slightly higher Miller capacitance than the 12AT7 in the SSE. I have noticed a measurable drop in high frequency response with a 100K pot set at mid range which is worse case with a typical low impedance source like a CD player. This may not be audible, but would be with a larger value like 250K or 1 Meg.
My setup was SY's HMN -> 100K TKD -> TSE. I paralleled 15K with the each channel at the attenuator to drop it to ~10K, as noted above. At 3/4 volume, shorting the resistors in and out, I could easily hear the highs were attenuated with 100K vs. 10K.
Old 19th February 2014, 12:52 AM   #12
moggi1964's Avatar
Thank you JP.
Makes me feel the 25K will likely be fine and the 'fixes' they post give me a chance to attenuate it if necessary to become a 10k.
TEAC RH 500 Amplifier Vista Phono1+ w/ TEAC TN-400. Loth-X Ion 1 BS & Emotiva XDA2. WIP: Tubelab SE 300b
Old 19th February 2014, 01:56 AM   #13
JP's Avatar
My post was in response to George that the high frequency attenuation from 100K was something I could hear - he said it may not be audible.
You'll be dandy with 25K - there wouldn't be any need to go lower with the TSE.
Old 19th February 2014, 02:14 AM   #14
moggi1964's Avatar
Gotcha! This is a great forum for ideas and feedback.
Attenuator chuka Solid State 1 24th May 2009 04:57 AM
attenuator Matt MacBeth Solid State 1 18th November 2006 01:56 PM
P-1.7 attenuator pinco Pass Labs 1 17th October 2006 08:48 PM
Stepped Attenuator officeboy Parts 3 6th May 2004 03:32 PM
Attenuator Raka Chip Amps 8 13th June 2003 08:14 PM
Copyright 1999-2017 diyAudio
