Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 26th February 2014, 12:16 AM   #21
bobrown14 is offline bobrown14  United States
Hey folks I'm getting ready to build a KT150 set of mono blocks and finally got the tubes. For shites and giggles I thought I'd drop em in my SSE ... Got a good run it last night for a good 3 hrs spinning vinyl and sipping wine etc. Right out of the box fresh they sounded pretty good, very good actually and I'm running this SSE from a 350-0-350 that is running plate voltage right around 350V loaded down (with KT88s) I haven't measured the loaded voltage with these but I would expect the same .... anyhow they sound fantastic. Something about the bass seems cleaned up more and just a feeling but they seem a little more 3D sound stage. I'm not all that good with verbage to describe sounds but I do notice a positive difference and I'm not talking a more warm sound just a little cleaner sounding with more bass and wider deeper sound stage. I've got the amp on right now but I'm in my shop so they could be up in smoke by now!! I doubt it tho. I did modify the power supply some from George's design. My C2 cap is 470uF 500v with the added motor run 100uF so a little beefier than the original design. I have some VERY efficient speakers horn loaded mids and tweeters and 15" bass drivers @ 105+dB/m efficiency so I can hear and notice the bass cleaning up... At any rate here's a few pics for ya's. BTW Trooper sold me his old box so if it looks familiar that's why and HUGE kudos to trooper, he does such a mighty fine job on cases, the stone under the amp is Quartzite (I'm a professional stone guy) :
Old 26th February 2014, 05:52 PM   #22
the trooper is offline the trooper  United States
Thanks man!!!
Old 27th February 2014, 12:21 AM   #23
moggi1964 is offline moggi1964  England
moggi1964's Avatar
Great case and gorgeous stone.
Don't start giving me expensive ideas
Pioneer XCHM86. Vista Phono1+ w/ TEAC TN-400. Loth-X Ion 1 & Genesis II. WIP: Tubelab SE 300b
Old 27th February 2014, 07:20 PM   #24
Stone was free & the case I bought from Trooper at the Swap Meet! This was hands down the easiest amp build I've ever done. Of course having the case already pre built made it SUPER easy.
Still liking those KT-150 as well, I'm throwing a bunch of music at them and I like the sounds I'm hearing.
Bob
Old 11th May 2014, 12:18 PM   #25
Here's my iteration on this design. KT150 with 30W Hammond transformers. NOS Stancor 400-0-400 PT, everything under the hood is beefed up. Loaded voltage at the plates is 412v. I don't want to run this without tubes!! Finished this one yesterday, transformers dont even get warm, still breaking in so I haven't plugged in any other speakers than my bench speakers, but those get pretty loud. I'll hook up to a proper set of speakers after family fun today. This amp weighs in at +40#s!!
Bob
Old 12th May 2014, 04:58 PM   #26
Here's a pic of my KT150 - don't know what happened in the previous post, I lost those pics for some reason.
Bob
Old 15th June 2014, 02:55 AM   #27
So if I had 5k output transformers, with 8 and 16 ohm taps, I could swap kt88s for kt150s and they would see 2.5k load on the 16ohm tap?
Bob that amp is a beauty!!!
Old 9th February 2015, 02:12 PM   #28
Victorinox is offline Victorinox  United States
Agreed and want to build one. Is there schematics available?
Old 9th February 2015, 04:47 PM   #29
You can build this with the Tubelab SSE board or use George's schematic found on his website here:
Tubelab SSE | Tubelab
The SSE board works fine for a 20-25w/ch version you need to up-rate a few parts for extra voltage/current as well as getting a larger power transformer. I've used a 400-0-400 and also a 425-0-425 PT, just need enough amps to handle the draw. If you crank up those KT-150s for a lot of power be sure your PT is worthy. If you let the amp idle with no sound the PT tends to warm up some! Pretty much SOP with SE amps or any tube amp really never a good idea but those big bottles like some current so that's the only thing I kinda worry about, I just don't leave my amp sitting on with no sound and go make dinner or something you get the idea.
Bob
Old 9th February 2015, 04:54 PM   #30
Hi Bob Hows it going? Finish that last Simple SE yet? I'd love to see some pictures
Kt150 simple seHide this!Advertise here!
Comparison KT150 versus KT120 es345 Tubes / Valves 58 20th January 2016 10:47 AM
kt150 cyclecamper Tubes / Valves 38 16th December 2013 01:17 PM
Tubelab SE vs Simple SE Pez Tubelab 25 29th October 2011 02:16 AM
Simple SE Simple Power Drive? Skorpio Tubelab 1 5th May 2011 09:45 AM
Tubelabs SE vs. Simple SE ?? albireo13 Tubelab 16 21st February 2010 09:00 PM
