Checkout problem TSE. - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 20th February 2014, 05:40 PM   #11
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
It seems like there is some kind of error around that part of the circuit. Are you sure that you have all of the correct resistors in place for Vadj?
Old 20th February 2014, 06:37 PM   #12
I will check it out again.thanks
Old 4th March 2014, 12:24 PM   #13
Replaced the resistors r1/r2/r35 . Now i have 5volt at the filament.
Next step in the checkout, another problem. At the 5842's i have B+ on the plate/gnd (pin 9) , that is when i use both tubes, with just one 5842 i get eventually at the target 175v. first it surges to 440v in about 10 seconds then drops in another 30 seconds to around 175v. Both channels and tubes same behavior. Checked r16 and r17 seems oke. So I thought they went in temperature shutdown so I placed a bigger heatsink on the mosfets (2SK3564) no change. they are very hot to the touch (two seconds before I need to pull my finger away). tried with a small fan still no change.
I am still in the breadboard stage, star grounded to outlet(do I need to ground the pwt and choke housing in this stage?)
My b+ is at 417v without the 300b's.
I welcome some suggestions.
Old 4th March 2014, 06:21 PM   #14
Are you following TSE checkout steps exactly the way it's written?
Old 4th March 2014, 09:30 PM   #15
I followed the instructions to the letter. I ll post the measured values tomorrow.
thanks for the reaction.
Old 5th March 2014, 10:37 AM   #16
My measurements:
no tubes:
B+ -0 v
B- -292v
filament 4.97v
with rectifier:
B+ 430v
B- 292v
filament 4.97v
grid -143v
rectifier+5842
B+ 425v
B- -288v
5842 plate to gnd left 248v
5842 plate to gnd right 237v
(is adjustable but only up)
voltage across r16/r27 = 3.21v
voltage across r17/r28 = 0v
Old 5th March 2014, 05:23 PM   #17
Are the trimmer pots right value or installed correctly? Or, see below.
Sounds like something is wrong with U2 or U3 chip. I've had issues with U2 chip. See this thread.
Old 5th March 2014, 06:00 PM   #18
R16/R27 should be around 3volt, shouldn't it? Before my filament problems, i had the right voltage on the plates. What could have changed?
Old 9th April 2014, 03:46 PM   #19
I have the tse working. The problem was with the 5842`s.
Replaced them and now sound is excellent. Even on my 85dB OB full range. .
I do have a little problem.after about 10 minutes of use the power drops. It looks like a temperature fail safe. tried it with a little pc fan on the mosfets but not much, if any, difference.
I don't have any silver paste at hand, is that much difference anyhow?
Still in breadboard state but these are my measurements with al the tubes mounted.
B+ = 394volt
300b filament 4.96volt
5842 = 175volt
bias 64 ma
any suggestions would be much appreciated.
Old 9th April 2014, 08:05 PM   #20
Where were the defective 5842 bought from?
Try 66 - 68mA bias and see how it is.
TSE checkout help positive grid voltage pbkrag Tubelab 1 21st December 2013 10:12 PM
Checkout double check. mudchute Tubelab 2 9th April 2013 12:27 AM
TSE checkout-unable to adjust 5842 voltage stonehome Tubelab 26 11th July 2012 09:49 PM
45 TSE Checkout Fail Alan Hope Tubelab 13 17th January 2012 09:42 PM
Checkout for Simple Se royd55 Tubelab 1 3rd January 2010 08:09 PM
Copyright 1999-2017 diyAudio
