Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 2nd October 2013, 05:59 PM   #1
spendorite is offline spendorite  Canada
Default Transformer with dual high voltage windings
I'd like to try 6V6 tubes in my SSE but the B+ from my Edcor XPWR035 is
too high for these.
Is this Edcor dual high voltage power transformer suitable for switching
between 6V6 and KT88 and other tubes ?
EDCOR - XPWR144-120/240
The dual voltages are 760V and 640V (380-320-0-320-380) at 200mA
which are a little bit above what Tubelab recommends.
The 6.3v main filament winding is rated for 3.5a, below what Tubelab
recommends so any problem here ?
This one is also much lighter than the XPWR035, 6.33lbs vs 9.75lbs
Opinions anyone ?
Old 3rd October 2013, 04:55 PM   #2
Sodacose is offline Sodacose  United States
Sodacose's Avatar
What type of rectification are you using? Choosing the right voltage drop will probably allow you to use that HV without problems.
Not sure about the heater draw, though.
Old 3rd October 2013, 08:49 PM   #3
Yes it is the low 3.5a on the 6.3v heater supply that is putting me off.
It is fine for the 5v rectifier supply.
Anybody else have any comments on this ?
Old 3rd October 2013, 09:47 PM   #4
Sodacose's Avatar
6v6 data sheet says about .5A heater draw. 12AT7 is less than half an amp. You'd be covered with 3.5A.
EL34's or KT88's, on the other hand, are 1.5A+ so you would be really pushing it.
If you're willing to wait on an Edcor, have you considered having something custom built (as in not choosing a pre-configured transformer)?
Old 4th October 2013, 12:33 AM   #5
I don't know, maybe later on I'll just build a smaller SSE for 6V6 tubes,
problem is I have too much equipment and no more space which is why
I was thinking of a combo amp using a dual high voltage xfrmr.
Old 4th October 2013, 02:54 AM   #6
Sodacose's Avatar
What about a small transformer dedicated to the heaters?
Transformer with dual high voltage windingsHide this!Advertise here!
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 09:05 PM
isolation transformer - high voltage. atmars Tubes / Valves 7 16th July 2008 05:34 AM
high quality 10A dual voltage regulator sunrise Solid State 32 1st December 2006 12:57 PM
Transformer voltage too high for 300B amp Jaap Tubes / Valves 4 13th January 2005 01:09 PM
high-voltage regulated dual power supply zzz Solid State 1 17th September 2002 02:15 AM
