Low dcr choke in sse - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 28th September 2013, 12:56 AM   #1
Sodacose's Avatar
Default Low dcr choke in sse
I have a 29ohm Dcr choke that I intend to use in my SSE. I also have a 5W 100ohm resistor. Should I just wire these in series? Any other considerations?
Old 1st October 2013, 02:59 PM   #2
Sodacose's Avatar
Bueller?
Old 1st October 2013, 03:51 PM   #3
JonSnell Electronic's Avatar
Why would you need the resistor as well?
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 1st October 2013, 05:22 PM   #4
Sodacose's Avatar
Is the DCR of the choke unimportant? Most of the information on chokes for this design that I've read have referenced an ideal DCR of 150ohms. Here's the schematic to the design in question:
Schematic | Tubelab
Edit: Seems the lower DCR may result in higher B+? Can anyone ballpark how much higher? I have 350V secondaries, a 5AR4 and intend to run KT88s.
Old 1st October 2013, 07:27 PM   #5
Sodacose's Avatar
Hmm, after playing around in PSUD2 (which I've never used before and it's awesome), it looks like there's a very small change in B+ (something on the order of 5V). That's if I'm using it correctly.
Anyone else with opinions on the DCR value of an L in a CLC?
Old 1st October 2013, 10:27 PM   #6
If the choke is in its correct position, after the valve rectifier, then what do you need the solid state diodes for? Extra voltage? (around 14v drop is in evidence from most valve rectifiers).
Old 1st October 2013, 10:33 PM   #7
kevinkr's Avatar
The diodes are an option. Some builders install them so that they can compare amplifier performance with tube or solid state rectification.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 3rd October 2013, 04:22 PM   #8
Sodacose's Avatar
Looking at PSUD2, it appears the biggest change is a higher current draw on the caps (max and mean). Voltages are slightly higher, but it's pretty mild. After thinking about it, this makes sense to me. I'm going to try it out and see how it goes.
Should I play with the fuse rating though? I was planning on using a 2amp fast-blow (as I've seen recommended). The max current spikes about 50% higher on C2 and L1 at startup with this 29ohm DCR choke than with the 150ohm recommended DCR.
Old 4th October 2013, 03:41 PM   #9
Sodacose's Avatar
Just in case anyone else is ever wondering the same thing about their build, here's an update.
So I chickened out and used the 100ohm 5W resistor in series with my choke. Those calculated current draw numbers worried me a bit and I don't have an inrush limiter on the primaries (though there's one in the mail).
Amp works fine. Might have worked otherwise, but I feel a little more confident every time I flip the switch with that resistor in there.
TubeLab SSE choke / component choice? normaldotcom Tubelab 10 5th October 2013 02:49 AM
Auricaps in SSE and SSE as a guitar amp. DanP Tubelab 5 12th July 2010 09:20 AM
EV SP12C with too-low output and too-high coil DCR... jon_010101 Multi-Way 2 21st June 2009 09:31 PM
Tube rectified LC PS for 6SN7 Aikido - choke DCR question LowRedMoon Tubes / Valves 3 20th June 2008 05:20 AM
Pro and cons high DCR filter choke reaction Tubes / Valves 6 20th March 2006 08:24 PM
Copyright 1999-2017 diyAudio
