Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 30th August 2013, 08:29 AM   #1
amandarae is offline amandarae  United States
amandarae's Avatar
Default 6F6G In SE
Anyone tried 6F6G's on their SE amp? Can I use it with Zs=5K ohms and Rk=560 ohms?
Thanks!
Abe
Old 25th September 2013, 01:06 AM   #2
w5jag is offline w5jag  United States
Yes, if your SSE was built for the smaller dissipation tubes. Probably not, if you built it for the larger power tubes. A search in this sub forum will provide you some information.
I have 6F6GT's in a low power SSE right now. My anode (plate) voltage is 322, the cathode sits at 25 volts, and, with a 680 ohm cathode resistor, that's 11 watts plate dissipation, almost the maximum for a 6F6, but this is the Tubelab forum, after all.
I just threw this amp together and will hopefully get a chance to document it soon.
Win W5JAG
Sent from my Windows 8 phone using Board Express
6F6G In SEHide this!Advertise here!
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 02:51 AM
Small, high quality 15v PS to drive an SE/SE Wire MisterRogers Power Supplies 0 13th June 2012 02:36 PM
OPC’s The WIRE – Latest Generation - PCBs for sale (4x BAL-SE, 1x SE-SE, 1x PSU KIT) fualcr Swap Meet 0 16th February 2012 12:39 AM
6F6G Amplifier sorenj07 Tubes / Valves 40 17th May 2010 11:15 AM
6F6G UL Amplifier sorenj07 Tubes / Valves 20 3rd August 2008 06:43 AM
