My Simple P-P Build My Simple P-P Build - Page 6 - diyAudio
Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 16th October 2013, 01:25 AM   #51
Einric is offline Einric  United States
Einric's Avatar
Thank you so much.
It looks like triode mode can have fewer connection errors so maybe I will try changing that also.
I will be working on this more tomorrow night.
Old 6th June 2015, 07:03 AM   #52
Sprags is offline Sprags  United States
I know it's been a while since anyone has posted a reply to this but...
Can you recommend an Edcor transformer that is equivalent to the Hammond power transformer? Or if that isn't the way to interpret this can someone tell me which Edcor transformer would work? I read the TubeLab pages and I just don't get it. I'm new to trying to learn electronics...been a Mechanical Engineer all my life. Sorry for the trouble.
Old 6th June 2015, 08:31 AM   #53
zman01 is offline zman01  Bangladesh
My Simple P-P Build
Sprags,
This is for a Tubelab SPP build?
2 options I found from Edcor:
https://edcorusa.com/xpwr172
https://edcorusa.com/xpwr131
The Edcor XPWR172 has a lower voltage rating (your B+ likely to be slightly lower), but is rated for 200mA vs minimum George's minimum recommendation of 175mA.
The Edcor XPWR131 has voltage rating of 660v which is slightly higher than 650v mentioned by George, and the current rating is on par at 175mA.
6.3v and 5v rails are adequate for both of the transformers.
Old 6th June 2015, 08:36 AM   #54
cjkpkg is offline cjkpkg  United States
Check this thread post #9 in particular...it is my el84pp amp...not the simple pp but specs should match. This amp holds the voltages nicely.
http://www.diyaudio.com/forums/tubes...rnal-site.html
Old 8th June 2015, 12:17 AM   #55
Thanks for the link cjkpkg. Einric has been good and we've been communicating about this and perhaps a SSE build.
I think I'm going to stick with the SSE build for now.
Old 8th June 2015, 07:16 PM   #56
My Simple P-P Build
The SSE is a sweet sounding amp and also a slightly easier build that the SPP.
Old 20th June 2015, 01:53 PM   #57
chilihed is offline chilihed
If you still have problems with hum, make sure that your top plate and bottom plate are both connected to the same ground. That solved my hum problem with my TSE 300B. Was driving me crazy and one little thing changed everything.
My Simple P-P BuildHide this!Advertise here!
Simple P P build cost millerlitescott Tubelab 17 23rd December 2011 12:19 AM
simple se build skipper Tubelab 151 2nd October 2009 12:47 PM
looking for simple speker build help colin.hepburn2 Full Range 19 20th September 2008 12:55 PM
a simple amplifier to build? testarossa2k Solid State 9 13th December 2006 08:30 PM
Copyright ©1999-2017 diyAudio
