Tubelab Simple P-P Choke - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 7th July 2013, 04:41 AM   #1
Einric is offline Einric  United States
Einric's Avatar
Default Tubelab Simple P-P Choke
I am in the process of building a Simple P-P and I have a couple of choices for chokes.
I have a C-12X 6H 165ma 160Ω and a 10H that is slightly larger but I don't know the ratings on it.
Will a 165ma 6H choke do the job for the simple P-P?
Thank You
Old 7th July 2013, 06:54 AM   #2
IIRC my PP's (have 3 of them) all pull between 185-200ma's so the C-12X would be a bit small. If you can wait a couple of days I'll measure the voltage drop across R1 to give you an accurate figure.
Ron
Old 7th July 2013, 04:08 PM   #3
Einric's Avatar
Sure, Thanks, I'm not in a great hurry since I don't have my Iron ordered.
The $30 to order an Edcore choke with won't break me.
But, by all means please let me know.
Old 10th July 2013, 05:02 AM   #4
I measured my 3 Simple PP amps in 5 different configurations with different power transformers. The average current through R1 was 192mA.
The amp that uses a 600VCT Edcor transformer had a current draw of 194mA.
Old 10th July 2013, 12:36 PM   #5
Einric's Avatar
Thank You, so a 200mA choke is what I need.
Simple PP @600VCT needs a 200mA choke under standard conditions.
Old 12th July 2013, 03:21 AM   #6
Einric,
Sorry for the delayed response. Yes the 200mA Edcor should be fine.
After searching in the basement for a couple hours I managed to find a choke close in specification to the Edcor. Connected to my board mounted Simple PP the choke improved the signal to noise ratio about 8dB versus the same amp with a resistor at R1. Impressive.
You'll probably have to be careful with output tube selection since the Edcor choke has half the resistance of the normal 150 ohm R1.
Ron
Old 12th July 2013, 12:27 PM   #7
Einric's Avatar
would anything be wrong with a resistor in series with the choke to make up the difference, or is that not really needed?
Old 12th July 2013, 11:23 PM   #8
Einric's Avatar
It looks like the Triad C-14X is perfect, 6H 200mA 150Ω.
Best of all it is $18 @ Mouser.
Old 13th July 2013, 12:38 AM   #9
Wow, that's a great deal & it should work great. Make sure you order it right away though. They only have one in stock.
Old 13th July 2013, 02:47 PM   #10
Einric's Avatar
Onlinecomponents.com has over 100 in stock for the same price.
TUBELAB SIMPLE SE rwlightner Tubelab 9 25th September 2016 12:51 AM
Tubelab Simple P-P booangler Tubelab 669 23rd March 2016 04:37 AM
Tubelab SE choke magnetman Tubelab 12 11th July 2012 01:59 AM
Simple SE Tubelab.com Fenn Tubelab 36 14th October 2010 01:42 PM
Tubelab Simple SE v.2 nic6paul Tubelab 3 1st November 2009 12:59 PM
Copyright 1999-2017 diyAudio
