Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 9th June 2013, 09:14 AM   #1
gmonno is offline gmonno
gmonno's Avatar
Default TSE : inverting red and yellow cable
Had a good working TSE, minor issues that Boywonder & Evenharmonics helped to solve.
Going to set the final configuration, it happened to INVERT red and yellow wires (I should have learned not to do these things and play with my daughter).
Result : 450V were 5V was supposed and obviously 5V were 450V, a very BRIGHT light from the 5AR4 and .... silence.
After correcting the error tried to put another 5AR4, the strange thing is that B+ arrives to 150V more or less and then begin to go down.
What may be?
Would it be possible that the choke (R4) is gone?
Or the FRED (D2, D3)?
I really have no idea.
Thanks for all help or suggestion.
giuseppe (madrid)
Old 9th June 2013, 09:36 AM   #2
gmonno's Avatar
Just discovered that R5 was gone.
This means that to be sure would be better substitute R6, R7, C6 and C7 too?
giuseppe (madrid)
Old 9th June 2013, 02:48 PM   #3
Evenharmonics is offline Evenharmonics  United States
Measure those with multimeter and see if resistors hold their value. If not, replace. As for the capacitors, someone else may know how to check accurately.
Old 9th June 2013, 06:21 PM   #4
gmonno's Avatar
WORKS!!!
It was only R5, just change it, all checks again and ... voilá ... music.
Thanks all
giuseppe (madrid)
TSE : inverting red and yellow cableHide this!Advertise here!
Bass preamp: non-inverting an inverting tone stack (opamp) Fredde79 Instruments and Amps 13 9th January 2013 07:03 PM
Plessey Red/Yellow/Black Electrolytics MCampbell Parts 6 14th February 2011 11:51 AM
Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB Alexander Rice Chip Amps 9 27th March 2004 06:53 PM
