Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 7th May 2013, 06:40 PM   #31
scott17 is offline scott17
Default Panasonic DMF
I've used many of this type:
DMF Series - Panasonic Electronic Components - Chassis Mount | Dynamic Catalog | DigiKey Corporation
They are oil-filled BTW:
http://www.panasonic.com/industrial/...il-filled.aspx
I included these in a kit that I once offered. Excellent performance. The best feature of all is the cost. Shhhh!
Old 7th May 2013, 08:32 PM   #32
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Motor run caps can be either electrolytic or film. The latter tend to be more reliable in practice while the former are cheaper.
For this application, you specifically want a film cap. Using a film motor run cap is a cost-effective way to find a high-capacitance film cap.
Old 7th May 2013, 09:34 PM   #33
Sgrilli AD is offline Sgrilli AD  Brazil
I really liked the Panasonic DMF, but Digikey asked me $40 to ship + $16 of cost for two peaces.
I found this one (as mentioned in the thread #22), but with different specifications (440V - 40uF). How about installing 2 in parallel? Is enough? or would be much capacitance?.
The final cost of the two + shipping would be around $31.
Many thanks
Old 7th May 2013, 10:21 PM   #34
Two in parallel would be 80uF. The value of capacitors in parallel are the sum of the values. Multiply the AC rated capacitor voltage by 1.414 to get the DC voltage rating. In this case, 440 x 1.414 = ~622VDC
Many thanks
Old 7th May 2013, 10:51 PM   #35
boywonder is offline boywonder  United States
boywonder's Avatar
You could also parallel one of these with a 180uf-220uf (or so) electrolytic. That gives you additional capacitance and lower ESR.
There are usually lots of motor run caps available on Ebay, not sure if that helps your shipping $$.
Old 8th May 2013, 01:11 AM   #36
I´m not sure if VDC is an issue. How much VDC is the target (minimum and maximum)?
Thanks again.
Old 8th May 2013, 01:59 AM   #37
boywonder's Avatar
Thanks again.
For an SSE running electrolytics in the PS, 500V is pretty much the max for readily available electrolytic capacitors. Many motor run caps are rated for 370 VAC, and 370 x sqrt2=522VDC so these will also work fine. That would easily handle KT88 B+ voltages.
Motor run cap failureHide this!Advertise here!
motor run cap question Doug R Parts 3 26th October 2012 09:58 AM
CBB65 Chinese motor run cap? PreSapian Parts 0 11th January 2012 05:34 PM
Is this motor run cap suitable for SSE? Horsebox Tubelab 11 2nd November 2011 03:03 PM
Eyuda Motor Run Cap?? neonthecat Tubelab 3 5th May 2011 01:38 PM
Source for 100uf motor run cap. audiobliss Tubes / Valves 3 31st July 2008 03:15 AM
