Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 11th April 2013, 07:47 AM   #21
mudchute is offline mudchute  United Kingdom
2x Solen 47uF 400V Axial MKP Film Capacitor | eBay
Will do the trick? I have the space to fit two so I achieve the higher value and these are good value.
Old 19th April 2013, 05:29 PM   #22
bobrown14 is offline bobrown14  United States
Try this one... Just got one recently for an SE build:
Run Capacitor 100 MFD 370V Round AC Electric Motor HVAC 370 Vac V Volts 100 Uf | eBay
Bob
Old 20th April 2013, 05:47 PM   #23
I went for this in the end.
Claritycap TC range of PSU polypropylene capacitors homepage
The 70uf item. Compact and well regarded it seems. Probably make no difference but at least I can get it under my chassis!! Once thats in and once I've fitted another CL-90 in the b+ my amp will officially be done.
I've some reissue Mullard EL34's in there at the moment and they're superb. I've tweaked my speakers a bit by adding some wadding to alter the sound and its all really starting to come together. So much so that I'm now looking at the Tubelab SE. I wish I went for that now instead of the simple. I was listening to a Je labs 2a3 equipped set amp a few weeks back and, although I wouldn't say it was better it was considerably different to mine in sound. I might try for a cheap (it never ends up like that) TSE build in order to have the best of everything...
Old 22nd April 2013, 04:09 PM   #24
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
That looks like the real deal. I actually had found some super compact high-voltage film caps on Mouser or Digikey or the like. I think they are 60uF. They are PCB mount, but can be made to work in a clamp. Sorry, I completely forgot that I had them.
Haha...yeah that's how it goes. Starting searching for tubes before you invest too much in the TSE design. The input/driver tubes are getting difficult to find for a reasonable price. I wonder if George will redesign that part of the PCB some time and put something more "modern" there.
Old 28th April 2013, 07:45 AM   #25
Its definitely on the cards for a future project that's for sure. I might do as you suggest and search for driver tubes prior to taking the plunge.
I fitted the 70uf claritycap and its working well. A noticeable improvement over the 100uf motor run cap so definitely recommended
I'm having problems with speakers now though. I'm using frugel horns with ma alpair 7 drivers and on certain mid to high frequency notes they become a bit ear splitting which is a shame as elsewhere they sound superb. I noticed the same when pairing my amp to a friends kef stand mount book shelf speakers, an occasional really bright cringeworthy moment that's got me baffled.
Old 5th May 2013, 04:24 PM   #26
ranhaber is offline ranhaber
ranhaber's Avatar
I have a Claritycap TC 220uF 700V and a simpler one NICHICON KX 220uF 450V.
Should i use them both as C5 on my TSE amp? Or only the Claritycap?
Ahh... And why please :-) ?
Old 5th May 2013, 11:33 PM   #27
boywonder is offline boywonder  United States
boywonder's Avatar
You can run the caps both ways. 220uf for C5 is adequate, 440uf will give less B+ ripple (hum). If you run them both in parallel you'll get two potential benefits; twice the capacitance and the film cap will have a much lower ESR than an electrolytic.
It's somewhat common to bypass a PS electrolytic with a film cap to reduce ESR.
The best approach is to try the amp with just the 220uf ClarityCap and then both caps in parallel. The caps in parallel will measure better, but let your ears be the judge.
Old 7th May 2013, 05:53 PM   #28
Sgrilli AD is offline Sgrilli AD  Brazil
Default Motor run cap option
Hello,
Would this capacitor be a good option for SSE?
Thank you all.
Old 7th May 2013, 06:05 PM   #29
AS a motor run/supplemental capacitor? If so then no I'm afraid, the one you have there is electrolytic.
That is the same as the one I put in mine initially not realising it was electrolytic (I just saw 'motor run cap' and didn't read on) and it opened up spilling its electrolyte. No good I'm afraid.
Old 7th May 2013, 06:38 PM   #30
Yes, I would use it as auxiliary power supply cap.
I thought all motor run caps are electrolytic. Am I wrong?
My problem is that here in Brazil we do not have anything like it and import fees plus the cost of shipping are completely unfair. A good capacitor that costs about $30 in the USA come here for almost R$160,00.
Totally impractical!
Anyway, thanks mudchut, for the help. I'll keep looking for a good and cheap options.
Motor run cap failureHide this!Advertise here!
motor run cap question Doug R Parts 3 26th October 2012 09:58 AM
CBB65 Chinese motor run cap? PreSapian Parts 0 11th January 2012 05:34 PM
Is this motor run cap suitable for SSE? Horsebox Tubelab 11 2nd November 2011 03:03 PM
Eyuda Motor Run Cap?? neonthecat Tubelab 3 5th May 2011 01:38 PM
Source for 100uf motor run cap. audiobliss Tubes / Valves 3 31st July 2008 03:15 AM
