SSE grounding
Now that mi. warmed a bit I got out to the shop and drilled my top plate. Amp has been running in a temp set up. Pic of layout included. The input jacks are on top and I take it that I come off one of the grounding lugs and run to the power input ground, everything else grounds thru the plate? (I will check every thing with my multimeter)
