Tube / Valve recommendations - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 14th May 2013, 01:00 PM   #11
pbkrag is offline pbkrag  United States
I've employed the switch rknize has posted about. It's switches between 6 different bias resistors. And I roll 3 different rectifiers. jj 5ar4/gz34. an old RCA 5u4gb and an old RCA 5y3gt. Between the bias selector and the different rectifiers I can pretty easily adjust to the proper current. for the 350b on my SSE the 5y3 with 430 ohm cathode bias resistor works well.
Old 19th May 2013, 05:36 PM   #12
Originally Posted by beeah View Post
The SED EL34 is a very fine tube indeed.
I've also read on numerous forums that the "SED/winged =C=" EL34 is the best...I have a Velleman K4040 PP amp that uses 8 EL34's, but I have Svetlana's in there now. Someday I might pick up some =C=, but I'm gonna pay dearly for them(they ain't cheap!!!)
Linn LP12 | Origin Live Silver Tonearm | Ortofon X5-MC | Velleman K8021 Pre | Velleman K4040 | Decware ZKIT1 | FISHER FM-100-C | Fisher 500C | Altec Lansing 874A Segovia | Marantz Imperial 6-G | Decware Mini Torii II :P
Old 29th September 2013, 11:44 AM   #13
I've settled on the Electro Harmonix KT88's. The best of everything. I've not thought about changing tubes since.
Tube recommendations anyone? pcb121055 Tubes / Valves 10 31st May 2015 02:25 AM
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 04:11 AM
Recommendations for a valve amp kit Fivetide Tubes / Valves 13 6th August 2011 12:43 AM
can't find valve art tube - and glowey tube pic wicked1 Tubes / Valves 23 10th February 2009 12:54 AM
Copyright ©1999-2017 diyAudio
