Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 15th April 2013, 11:08 AM   #51
RuiR is offline RuiR  Portugal
Originally Posted by rknize View Post
Very simple test for a MOSFET. There are better ways using a small battery instead of the meter to charge the gate. Just Google it.
MOSFET testing
Since the resistor method is working, I am really confused about why your CCSs are failing.
It works now, at least for a full week
I have to thank you Russ for the help and patiente, the resistors test was essential to see it was a mosfet failure I order DN2540 ones and installed them. They are working.
I have now 260/270/280VDC (it depends wich valve i use) 12AT7 plate voltage and 2.2VDC cathode... the valve runs at 10mA. A little high but i don't have a more suitable resistors.
Thank you
Old 15th April 2013, 06:46 PM   #52
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
I'm glad that you figured it out!
Mosfet breakdownHide this!Advertise here!
TO220 isolation kits breakdown tomchr Tubes / Valves 23 22nd March 2012 07:10 AM
Preventing bjt breakdown Stretto Solid State 16 27th July 2011 11:17 AM
Dynaco PAS transformer breakdown revintage Tubes / Valves 3 8th November 2010 03:15 PM
strange speaker breakdown makeb4break Multi-Way 2 29th March 2009 09:58 AM
Breakdown between solder tags? eeka chu Tubes / Valves 2 10th February 2004 10:14 PM
