Mosfet breakdown - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 1st March 2013, 07:15 PM   #11
RuiR is offline RuiR  Portugal
Originally Posted by rknize View Post
Are you using FETs in place of the CCS? If the CCS is doing it's job, the voltage will vary as the CCS maintains a constant current. What is the voltage *across* R13/23 and R14/24?
I already taken them out I had the time and done it because i will be busier.
*across*? It had about 325v after R14/R24 and the same voltage before R13 and (i can't be certain) after R13
Apart from that, yes it does sound like a thermal issue. You are not using thermal paste? Have you adjusted the resistor values on your FETs so that you get the desired ~9mA of current through the tube?
I did use thermal in the first set, the one that take longer.
yes i did use 330Oh resistors with the IXCP10M45S - about 9.4mA and 185Oh when i used the DN2540 - ~10mA
Thank you Russ, i learned a lot from your posts when i was building it 1 year ago. I implemented the variable resistor switch
Old 1st March 2013, 07:39 PM   #12
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
By across, I mean putting a probe on each side of the resistor and measuring the voltage across it. That will tell you what the current is and how it may be drifting. I assume you were measuring relative to ground?
Others have used the DN2540 with good results. Maybe it is oscillating?
Old 2nd March 2013, 09:01 AM   #13
Thank you.
Yes, i measure to the ground, newbie but not that much
The first set i used was DN2540's
This is how i assemble them:
The two nuts are to gain hight so it can be pressed against the board
Old 13th March 2013, 03:29 PM   #14
Exclamation Lost.. need help please
Hi
I lost count the times i already dismantle this thing trying to spot why it doesn't work
I'm ending with a voltage after R14/R24 equal at B+ in R4, ~450/460VDC.
Before R13 and R14 i'm getting 12VDC at one side and 2VDC in the other With no voltage or a residual only at R10/R20
I'm starting to despair and i might pick a shovel and bury it
With the mosfets changed i managed to lift their tracks, i replaced them with wire and the circuitis fine.... i looked so many times to them and i can't see any problem there
Please any thought? Even the the most odd one is welcome
Old 13th March 2013, 04:25 PM   #15
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
How did you insert MOSFET in the specified schematic? I can't see MOSFET's in that circuit.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 13th March 2013, 04:27 PM   #16
rmyauck is offline rmyauck  Canada
Maybe bigger heatsinks from an old computer CPU & computer 12V fans run on a lower voltage like 6-8V for quiet running would help as it's probably hot where you are also.
Old 13th March 2013, 05:00 PM   #17
Ehhhhhh, too much for a low current sink!
Old 13th March 2013, 06:44 PM   #18
It's on the left of the schematic Simple SE schematic
Anode to R14/R24
Gate to R19/R29
Kathode to R13/R23
Thank you
Old 13th March 2013, 06:48 PM   #19
It's a proven design with others running without fan aid. I'm doing something wrong or something is malfunctioning
Thank you
Old 13th March 2013, 07:22 PM   #20
This wiring is true for constant current sources (like LM336) but isn't true for MOSFET's. You will need to rewire your circuit to use P channel MOSFET's as CCS or BJT's. You need to generate a voltage of about 3-4V between gate and source (depending of the polarity of the MOS transistor) to turn it on (Class A biased), and then adjust source resistor to get drain current you need. Power in it will be directly I * E across the mos, then multiply it by the thermal resistance from die to air, and you will get temperature rise in the MOS without the heatsink. If this rise is too high, use a proper heatsink needed to reduce temperature to normal (< 70 deg Celsius) value.
But, why not to use the other half of the 'AT7 as a SRPP?
TO220 isolation kits breakdown tomchr Tubes / Valves 23 22nd March 2012 06:10 AM
Preventing bjt breakdown Stretto Solid State 16 27th July 2011 10:17 AM
Dynaco PAS transformer breakdown revintage Tubes / Valves 3 8th November 2010 02:15 PM
strange speaker breakdown makeb4break Multi-Way 2 29th March 2009 08:58 AM
Breakdown between solder tags? eeka chu Tubes / Valves 2 10th February 2004 09:14 PM
Copyright 1999-2017 diyAudio
