TSE measurement over time - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 28th February 2013, 10:01 PM   #1
Default TSE measurement over time
Anyone kept a log of their TSE measurements over the years? Below are what I compared. White graph is from 2010 and green is from today. Granted, the measuring device calibration has been changed slightly since but I wonder what could possibly make the two graphs look so different from same amp 2.5 years later. Any thoughts? THD and THD+noise numbers haven't changed much but the extension of harmonics is somewhat scary (to me).
Old 1st March 2013, 01:45 AM   #2
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Have you checked the spectra of your source? That looks like signal generator noise to me.
Old 1st March 2013, 03:33 AM   #3
I did and it's fine.
Old 1st March 2013, 05:18 AM   #4
On thing I should add, both channels produce about the same characteristics so I'm guessing it's a common source.
Old 1st March 2013, 05:57 AM   #5
rknize's Avatar
Anything funky about the output wave form? Is the heater supply quiet?
Old 2nd March 2013, 06:05 AM   #6
You were kind of right. It was the source in an indirect way. The sound card and signal were fine but for some reason, when it entered the amp, something got added. Static maybe?
Anyway, I redid the measurement today and it looks normal. While I'm at it, I decided to play around with bias. As George mentioned in his TSE build steps, trying different bias and see how they sound, I measured 3 different settings below. First is set at 58 mA, second at 62 mA and the third at 72 mA. I find it interesting that as bias goes up, THD decreased but high order harmonics increased. As bias went down THD increased and high order harmonics decreased. How do they compare in terms of sound? It's going to be a time consuming and difficult process because there is no way for me to change bias quickly enough to make an accurate comparison. I'll report back in a few days if I audibly notice something between these bias settings.
TSE input jrobson Tubelab 7 9th December 2012 05:33 PM
TSE question.. Green77 Tubelab 17 28th September 2012 08:50 PM
TSE help evanc Tubelab 2 12th June 2012 11:14 AM
Underside Pics Of TSE amandarae Tubelab 6 1st December 2011 05:13 PM
TSE Parts TerribleT Tubelab 12 14th October 2011 05:55 PM
Copyright 1999-2017 diyAudio
