Basic questions on configuring Tube AMP - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 4th March 2013, 04:48 PM   #21
boywonder's Avatar
No, just unsolder the two green transformer leads connected to T1-GRN.
What is the value of R3?
Old 4th March 2013, 04:51 PM   #22
boywonder's Avatar
Are you trying to check the value of R4 with a meter in-circuit? That usually doesn't work, as the current can be flowing all over the place. You need to have at least one end of the resistor disconnected.
Old 4th March 2013, 04:52 PM   #23
Originally Posted by sagi4422 View Post
Do you mean unsolder the 9pin socket pins ?
Well, interesting thing here. I checked R4 and find out it is 80K (instead of 150K) it is strange as I checked the package it arrived for model and number (but didnt the actual resistance).It may be the problem?
I usually double check resistors with a multimeter before installing them,
especially when there's only the color bands on them.
Old 4th March 2013, 05:29 PM   #24
boywonder's Avatar
me too.......it's a good idea.
Old 4th March 2013, 07:49 PM   #25
Well I supposed if I buy from a known firm, I should not encounter such problems.
Tomorrow I will unsolder the resistors and the pins and check what you suggested
Thanks.
Old 4th March 2013, 09:13 PM   #26
boywonder's Avatar
Sagi: Your resistor values are probably correct. Measuring them in-circuit with a meter is a fruitless exercise. At least one end needs to be disconnected to measure with a meter.
R4 and R3 make up a resistive divider to elevate the heater voltage. If your B+ is say 400V, with R4 a 150K and R3 a 10K, the filament winding is elevated to 25V by being tied to the node between the R's (ohm's law voltage divider). The heaters/filaments still see 6.3V, it's just elevated from ground by around 25V. This reduces the potential between the cathodes and the heaters and means less hum/noise out to your speakers, and it is a little easier on the filaments in the tubes.
Please also let us know what you are using for a fuse, to eliminate other possibilities.
Old 5th March 2013, 04:38 AM   #27
The fuse I used is 3.15A/250V . It was something I found in my house. It was written as T3.15A/250V so I dont know if its slow-bow or fast
Old 5th March 2013, 01:32 PM   #28
boywonder's Avatar
IIRC, the recommended fuse is a slow blow 1A-1.5A or so.
That's a little big.......don't go any larger or you'll risk damaging components.
If it's a fast blow, it will just have a metal filament. Slow blows have the filament wire wrapped around some kind of insulator.
The fuse on the top is a slow blow; the one on the bottom is a fast blow.
Do you still blow fuses if you unsolder the transformer filament leads?
Old 5th March 2013, 02:07 PM   #29
boywonder's Avatar
Sagi: What is your mains voltage? I have no idea what country you are in.....
If it's 240V, then a 3A fuse is too big.........it's marginal at 120V.
Old 5th March 2013, 02:47 PM   #30
What I have now are fast bo fuses. I am using 240V so I will buy lower amp fuses.
Anyway, should I wait to unpin the transformer-heater pins or is it possible to check it with the current fuses I have ?
Basic class D amp questions loheswaran Class D 11 10th May 2011 09:53 PM
Basic op amp optical compressor questions LarsXI Solid State 0 1st July 2008 11:32 PM
Some basic questions about s-5 amp kit mods fenpark15 Tubes / Valves 15 22nd December 2007 10:56 PM
Basic sub/amp questions Katokahn Subwoofers 3 1st November 2006 05:03 AM
some basic questions (ProAudio & horns) tech.knockout Multi-Way 2 11th April 2005 11:46 AM
Copyright 1999-2017 diyAudio
