Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 20th May 2013, 11:47 PM   #141
Sgrilli AD is offline Sgrilli AD  Brazil
Originally Posted by boywonder View Post
Sgrilli:
I don't know the answer to your question, but you need to consider what would happen with either or both switches in the "off" position. In either case, you have either the suppressor grid not connected to anything or the screen grid not connected to anything. For the most part, having tube grids floating is not a good idea.
For a couple of bucks, I would just get proper switches, or as Sagi mentioned, determine what mode you like during the build, and wire it that way.
Hi boywonder,
Great ... this is the answer I was expecting. Now I can make a more informed decision.
I'll proceed under the guidance received. First, I will test all combinations off the PCB and then decide what is the best way.
Thank you so much
Sgrilli
Old 21st May 2013, 05:39 AM   #142
sagi4422 is offline sagi4422
Basic questions on configuring Tube AMP
Good luck
Basic questions on configuring Tube AMPHide this!Advertise here!
Basic class D amp questions loheswaran Class D 11 10th May 2011 09:53 PM
Basic op amp optical compressor questions LarsXI Solid State 0 1st July 2008 11:32 PM
Some basic questions about s-5 amp kit mods fenpark15 Tubes / Valves 15 22nd December 2007 10:56 PM
Basic sub/amp questions Katokahn Subwoofers 3 1st November 2006 05:03 AM
some basic questions (ProAudio & horns) tech.knockout Multi-Way 2 11th April 2005 11:46 AM
