Basic questions on configuring Tube AMP - Page 13 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 12th April 2013, 08:07 PM   #121
Well 3v is ~10% . I need to recheck it in different times of the day to see whether this is the cause for the decrease in voltage . Anyway , I am using 6l6gc tubes and the measuremens were taken without the tubes .
Regarding the max volume , Is it possible that the POT is not covering the full scale of the available volume ?
Old 12th April 2013, 08:38 PM   #122
boywonder's Avatar
Not really, here's why:
The pot is a passive device, and it can only subtract (attenuate) the signal. When the pot is turned fully clockwise, it is essentially a short circuit, ie no attenuation/subtraction.
If you measure the pot wiper to the end terminals with the wiper at full travel clockwise, you will get zero ohms (or very close to it) from the wiper to one end, and the value of the pot in ohms from the wiper to the other end. Turn the pot fully CCW, and measure again; you will reverse the above. The pot needs to be out of the circuit to measure the various R's.
So, in summary, with the pot fully clockwise it's like no pot at all, ie zero attenuation. That's as loud as your amp is going to get for a given input signal. Keep in mind that different sources have different output levels as well, ie your ipod may play louder than your CD player, etc.
Old 12th April 2013, 08:49 PM   #123
Thanks . I will check this issue.
Old 12th April 2013, 09:25 PM   #124
PDL is offline PDL  United States
3v is .6% of 500v, I wouldn't worry to much about it.
Old 12th April 2013, 09:32 PM   #125
The change in voltage was not seen in the PS secondaries . It was seen in a place where formerly was 34v and now 31
Old 15th April 2013, 06:45 PM   #126
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
You were measuring the heater filament's DC offset to ground. It's not all that important. Did you see my previous post? I don't think that you measured the correct pins.
Old 19th April 2013, 06:26 AM   #127
I double check it and compared it to the schematics I got. It seems that I was measuring the right pins.
Anyway, the voltage values are OK.
Old 19th April 2013, 06:30 AM   #128
Almost finished, with the chassis.
Left are some painting issues and templates for the switches.
Old 29th April 2013, 10:03 PM   #129
Hi.
Another interesting question, can I use the Simple SE as preamp (in a certain configuration)?
I just got a nice vintage Sansui AU717 and I dont know how to handle more than one amplifier
Old 30th April 2013, 01:48 AM   #130
boywonder's Avatar
Default Can the Sansui be run as a power amp?
Hi.
Bi-amp with the SSE driving the tweeters (with proper protection) and use the Sansui for the woofers. You can also change the value of the coupling caps in the SSE for a higher cutoff freq when just powering the higher freq drivers. This makes life easier on the amp (and allows additional "apparent" power) since it does not have to pass the higher powered low freq signals.
Taking it one step further, you can throw an active eq between the source and the amps for easy x-over tailoring.
Basic class D amp questions loheswaran Class D 11 10th May 2011 10:53 PM
Basic op amp optical compressor questions LarsXI Solid State 0 2nd July 2008 12:32 AM
Some basic questions about s-5 amp kit mods fenpark15 Tubes / Valves 15 22nd December 2007 11:56 PM
Basic sub/amp questions Katokahn Subwoofers 3 1st November 2006 06:03 AM
some basic questions (ProAudio & horns) tech.knockout Multi-Way 2 11th April 2005 12:46 PM
Copyright 1999-2017 diyAudio
