Basic questions on configuring Tube AMP - Page 12 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 11th April 2013, 04:06 PM   #111
Another question,
I would like to check again the values of C1/C2 and R17 and R27 .
I already placed the pcb in my aluminum chassis so,to which pins in the socket tubes should I be connected to measure the above ? (I have the feeling the power is not as I measured 3 weeks ago)
Old 11th April 2013, 04:08 PM   #112
Here are some pictures
Old 11th April 2013, 06:05 PM   #113
boywonder's Avatar
Originally Posted by sagi4422 View Post
Hi.
Isn't the CFB switch in charge of inverting the polarity of the OPT's secondaries?
Note the "Note" on the schematic just above the feedback switch......
Simple SE schematic
Old 11th April 2013, 07:04 PM   #114
Yes I saw that,
With CFB, the UL is working. I didn't have the time to play with that much so until now I didnt find a different.Although that, I think the output power was decreased somehow after connecting the switches. Any chance to measure the DC voltage using the socket pins?
Old 11th April 2013, 07:28 PM   #115
boywonder's Avatar
The output power in triode mode will be a fair bit lower than UL.
Old 11th April 2013, 07:29 PM   #116
Old 11th April 2013, 08:16 PM   #117
boywonder's Avatar
Do you want to measure B+ voltage? Pin 3 to ground.
Here are the pinouts:
TDSL Tube data [EL34]
Old 11th April 2013, 09:08 PM   #118
OK.
This is my measurements now :
PIN2 - GRN - 31V
PIN3 - GRN - 0V
PIN5 - GRN - 497V
PIN6 - GRN - 497V
PIN7 - GRN - 31V
As indicated here, pin3 and ground gives 0V.
According to the first experiments I did, before I put it on the chassis, I have 3V less now. ?!
Old 11th April 2013, 09:22 PM   #119
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
I suspect that you counted the pins backwards and inadvertently tested pin 6 instead of 5:
2 - 31V
3 - 497V
4 - 497V
6 - 0V
7 - 31V
Pin 6 has no connection on EL34. You probably want to check pin 8, too.
Old 12th April 2013, 07:53 PM   #120
PDL is offline PDL  United States
The 3V difference could easily caused by your mains voltage fluctuating. I've seen my mains vary as much 3V, if not more in the summer when everyone cranks the AC.
Basic class D amp questions loheswaran Class D 11 10th May 2011 10:53 PM
Basic op amp optical compressor questions LarsXI Solid State 0 2nd July 2008 12:32 AM
Some basic questions about s-5 amp kit mods fenpark15 Tubes / Valves 15 22nd December 2007 11:56 PM
Basic sub/amp questions Katokahn Subwoofers 3 1st November 2006 06:03 AM
some basic questions (ProAudio & horns) tech.knockout Multi-Way 2 11th April 2005 12:46 PM
Copyright 1999-2017 diyAudio
