diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubelab (http://www.diyaudio.com/forums/tubelab/)
-   -   Novice SSE build (http://www.diyaudio.com/forums/tubelab/229426-novice-sse-build.html)
the trooper 6th February 2013 02:02 AM
Novice SSE build
Hello all, I'm planning a sse build and would like to go over some of the parts with anyone that will listen. This will be my first se amp. Looking for budget friendly parts where possible.
for output transformers: EDCOR - GXSE15-8-5K 74$
for power transformer: EDCOR - XPWR033-120 59$
for choke: EDCOR - CXC100-5H-200mA 39$
6l6gc tubes cathode resistors- 750
how does this look?
wintermute 6th February 2013 03:04 AM
Hi, I moved your thread to the tubes forum as I suspect that this wasn't specific to the commercial tubelab forum :)
Tony.
the trooper 6th February 2013 03:09 AM
Sry guess I should have been alittle more specific, this build will be using a Tubelab Simple Se board.
wintermute 6th February 2013 03:21 AM
ok sorry, moved back ;)
Tony.
boywonder 6th February 2013 03:35 AM
Looks fine to me.....I would suggest 500V rated caps, assuming your target B+ will end up somewhere between 450 and 500V.
They can be a little hard to find, but they are around.
rknize 6th February 2013 05:54 AM
Yeah, your B+ will definitely be on the hot side with that power transformer combined with the lower DCR of that choke. I would say that 500V caps are a must.
the trooper 6th February 2013 03:25 PM
Just for c1 and c2 positions right?
rknize 6th February 2013 05:08 PM
At a minimum C1, C2, and any aux cap you may add.
the trooper 6th February 2013 07:35 PM
Ok thanks for the tip, I'm gonna try and document the build here when I collect all the parts.
boywonder 6th February 2013 07:39 PM
Looks like you'll also be set up for KT88 operation if you desire.....perhaps pick up a few different cathode R values.
Resources saved on this page: MySQL 18.75%
