Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 12th February 2013, 04:35 AM   #21
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Because the circuit is cathode-biased, small changes in B+ from rectifier changes won't result in much change in the output tube operating conditions. The circuit automatically tries to compensate. The only way to do it effectively is to make the resistor itself easily swappable or have multiple resistors that are switchable.
Old 12th February 2013, 12:22 PM   #22
rock12 is offline rock12  United States
look at thread from march28,2010 SSE questions, post #61 shows a nice wiring diagram for a cathode bias switch somewhere there is a pic also
Old 13th February 2013, 02:57 AM   #23
the trooper is offline the trooper  United States
Will do thanks for the tip
Old 22nd February 2013, 01:32 AM   #24
Default sse build
Started working on the simple se top plate. I will be posting pictures of chassis this weekend
Old 22nd February 2013, 02:29 AM   #25
boywonder is offline boywonder  United States
boywonder's Avatar
Nice! paper templates......they work great!
Old 23rd February 2013, 05:09 PM   #26
Default chassis
And this is how you put burn marks on nice lumber.......I should have this built by the end of the day
Old 24th February 2013, 04:05 AM   #27
Default done
just needs a sanding and finish.
Old 30th March 2013, 10:27 AM   #28
gthang is offline gthang  United Kingdom
Your case work looks excellent. I'm planning and SSE project myself, was thinking along similar lines. What tool did you use to cut the 2mm? recess along the edge of the 4 pieces of wood?
Old 30th March 2013, 05:35 PM   #29
jrn77478 is offline jrn77478  United States
Judging from the tool marks, a table saw?
Old 4th April 2013, 04:01 PM   #30
Thank you for the compliment, I used a table saw for the recess and just mitered the corners. Blade must have some varnish build up. The top plate is from online metals. I would wait to have the metal on hand befor making any cuts, they only guaranty size to + or - 1/8"
Edcor just sent me a shipping notice so I should have this all done soon!
Novice SSE buildHide this!Advertise here!
Starting a SSE build neomat Tubelab 43 28th November 2016 09:52 PM
new sse build choosing parts rock12 Tubelab 9 24th January 2013 03:10 AM
Best way for novice to learn to build amp Taipan Construction Tips 22 16th December 2012 06:50 PM
Novice build of Silbury highfieldrebel Full Range 31 12th October 2011 05:05 AM
Novice speaker build bull041161 Multi-Way 15 1st October 2009 07:52 PM
