| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
my power switch has a 2.4volt led ?millivolts I was thinking of using the 6.3voltac off the heater line using a ln400x diode to a 10uf in parallel then a 2k resistor. I heard that the cap removes flicker in the light. do these values sound usable
#2 |
You might want a larger capacitor value. I would probably start with something like 100 uF. It really depends on the average current draw. More current would mean more ripple amplitude.
How much current do you want through the LED? A 2kOhm resistor won't give you much; maybe around 1.5 mA average. Something like 330 Ohms might give about 8 ma average. With 2k and 1.5 mA, the 10 uF cap would give about 50 mV ripple, peak-to-peak, out of about 2.5 V across the LED. That should be fine, I guess. But if you need more current, you can increase the cap value proportionately if you don't want more ripple amplitude. |
#3 |
If you use a full wave bridge the "flicker" frequency will be 120Hz
You will not notice it. R between 330R and 499R...depends on LED and how bright you want it.
Doug We are all learning...we can all help |
#4 |
#5 |
All the best stuff comes from Chian
If you move the cap to the other side of the resistor, it will work even better (fwiw).
#6 |
Generally the human eye doesn't notice anything above 25Hz - TVs and flourescent lighting are a testament to that.
#7 |
It depends on how fast the LED is. TVs have rather slow phosphorous and don't toggle from on to off on every refresh.
Some people get headaches from slow computer monitors.I've used LEDs in situations like this where the flicker is noticeable, especially when sweeping my eyes across the room. Anyhoo...if you don't notice the flicker it's not a problem. |
#8 |
subject is interesting enough on its own, but sorry, if I don't understand .....since its a tube amp, won't the tubes tell you when its on
#9 |
Now that just makes too much sense.
Frank |
#10 |
Only a few of them glow blue...
| LED Flashlight (SUPER LED BL-X8600) with power P = 3W otherwise | adorn751 | Everything Else | 1 | 9th April 2012 04:01 AM |
| How to connect power on switch and LED on TA2024? | gychang | Class D | 2 | 21st June 2009 01:35 PM |
| Ground isolation network / power switch wiring | DcibeL | Power Supplies | 2 | 5th April 2006 12:43 AM |
| Power switch and blue led questions | porfi4ever | Pass Labs | 12 | 25th April 2003 03:44 PM |
