| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
It's a GE 5 Star 6201 that was hiding, lost and unloved, in my stash.
Just sounds "better" than the new production JJ and EH Gold AT7s I'd tried previously. |
#2 |
All the best stuff comes from Chian
My SSE wore-out a JJ and the JAN tube that is in there is forming a clear spot in the top of the getter. I haven't checked how strong the tube is, but the SSE has a lot of hours on it since it was built. It still sounds fine.
#3 |
Glad this subject came up. I've been looking for the optimum 12AT7 for one of my Simple PP's. Seems like I should have some 5 Star 6201's in my box of 12AT7's and related types. I'll give them a try.
#4 |
The SPP is a different story. I had some interesting experiences with it using modern tubes. I ended up having to change some resistors to get the fixed bias of the phase splitter to work out right. NOS tubes worked fine as designed.
I actually gave George those problematic tubes. I wonder if he ever looked at them.... |
#5 | |
I believe I have a 6201, I will try to find it and see how it sounds. Thanks for the tip! Abe |
#6 |
+1 on the 5-star 6201.
The Telefunken 12AT7 is THE weirdest sounding tube I've ever experienced. |
#7 | |
What weirdness did you hear? |
#8 | |
Imaging was overly large and just, well, "off".It could have been a bum tube even though it tested ok, but as it was the only one I had I couldn't compare against another one. |
| 12at7 dc coupled to 12at7 cathodyne to drive EL34 | alexg | Tubes / Valves | 13 | 15th June 2012 11:50 AM |
| What is the best use of 12AT7? | Jay | Analog Line Level | 16 | 17th February 2012 04:35 PM |
| SSE / Thanks | shortwave | Tubelab | 4 | 30th October 2010 04:34 AM |
| Auricaps in SSE and SSE as a guitar amp. | DanP | Tubelab | 5 | 12th July 2010 09:20 AM |
| Can I use 12AT7? | Ahmad_tbp | Tubes / Valves | 6 | 25th January 2006 06:11 AM |
